Introduction: Mini Table Saw Crosscut Sled
Ever since I let my buddy use my older table saw in his shop, I’ve been meaning to remake a sled for my new one. As mentioned in the video, I have a larger sled. It’s a nice one from Rockler , the problem is it’s big and take up space when not in use. Not to mention, it’s usually not as easy to get to. To cut down on the hassle of taking it out for smaller parts, building this smaller version will allow me to have it close to the table saw.
Materials Used
- 3/4in plywood
- T-Track Kit – https://amzn.to/2RCt6Ze
- Wood Glue https://amzn.to/2RG92Fd
- Shellac https://amzn.to/2Rjy3H9
- Right to Left Measuring table https://amzn.to/2SSU78g
- Threaded inserts https://amzn.to/2M42o6u
- Screw for the T-Track https://amzn.to/2H87AYl
- 1/4-20 x 1-1/4″ Pan Head Screws
Tools Used
- Saw Stop Table Saw https://amzn.to/2M3x3km
- Rockler Sled https://amzn.to/2RFWnCl
- Clamps https://amzn.to/2RFVBoV
- Empire Speed Square https://amzn.to/2SOOLe2
- Cordless Sander https://amzn.to/2VLe6Hv
My Links:
- Woodworking Plans https://gumroad.com/diycreators
- Youtube http://bit.ly/1PtWJEd
- Instagram https://instagram.com/Morediycreators/
- Website https://diycreators.com/mini-crosscut-sled/
Step 1: Cut the Lumber
This sled is made entirely of ¾ in plywood. Here you can see the see all of the measurements.
Step 2: Make the Slot for the T-Track
To cut out the section for the t-track will need, you can go about this a number of ways. I find it easiest to do it on the table saw.
Step 3: Making the Sled Fence
Step 4: Joining the Fence to the Base
Locate the base and the fence, and then apply glue to the connecting point on the fence. Now, connect the two then add clamps. Finally, Check to make sure the base is squared to the fence
Step 5: Installing Threaded Inserts
Check to make sure the miter gauge is squared with the saw blade. Then, line up the sled to with the miter gauge. I know not all table saws come with a good miter gauge. In this case, you can make a miter bar. I gave a great example in the older table saw crosscut fence video on how to do this. The placement is optional, but the end of the sled (the short side) is placed 6in away from the blade. Honestly, there is a great chance this entire side will be cut off in the future.
Since my gauge has the slots for the bolts I marked and installed a threaded insert . These are greats for shop jigs and furniture. I highly recommend them.
Step 6: Making the Cut
After attaching the sled to the miter gauge double check to make sure it’s still squared to the blade. Now make your first cut into the sled.
Step 7: Making the Stop
To make the stop, locate the two pieces. Attached smaller part to the end of the larger piece. Then Drill out a 5/16’’ hole at the location of the T-Track.
Step 8: Prep Work
Step 9: Adding the T-track
I cut each T-Track down and placed them in the slot. Next, I screwed the tracks in place.
Step 10: Adding the Adhesive Tape
Adding the adhesive measuring tape is totally optional. It just makes things convenient having it in place.
Step 11: Test Cuts
Finally, make a few test cuts and see if you need to fine-tune anything. I hope you find this post helpful, for more projects like this subscribe to my website blog and follow me on youtube and Instagram .
