Introduction: Modify the Capability of Your Sound Card in Raspberry Pi
Introduction
In my Test Sound Card and Speaker instructable, I ran the program speaker-test to send digital sound to the sound card driver. The speaker-test program needed to call ALSA program. The ALSA program has a component called Plugin(s). Plugin is the heart of ALSA.
In this instructable, I will swap the speaker channel so that the Left Speaker will output the sound "FRONT RIGHT" and Right Speaker will output the sound "FRONT LEFT". I will NOT swap any speaker wire to achieve this. I will use an ALSA plugin.
This is not useful in itself. It is just a way for me to learn ALSA plugin.
Scope
This instructable will cover the following:
- Create a ALSA Virtual Device by using a type of ALSA plugin to swap the speaker channel.
- Use ALSA utilities to test sound card and sound device
This instructables will NOT cover the following
- PulseAudio
- OSS
Specifications
My Raspberry Pi:
- Raspberry Pi 2
- Rasbian based on Debian Version 8.0 (a.k.a Jessie)
- Advanced Linux Sound Architecture Driver Version k4.1.10-v7+
- Pulse Audio and OSS are NOT installed
- 2 speakers connected to Raspberry Pi's audio/video 3.5mm socket.
Step 1: Test Sound Card and 2XSpeakers
Complete the Test Sound Card and Speakers in Raspberry Pi instructable.
Step 2: Understand ALSA "Physical" Device and ALSA Virtual Device
An ALSA device refers to a specific capability of an ALSA Card. Therefore
an ALSA Card will have one or more ALSA device (to send sound) and may have another ALSA device (to receive sound) and another ALSA Device for some other capability.
ALSA created another concept called ALSA Virtual Device. ALSA Virtual Device is similar to ALSA Device in that it provides a capability to the ALSA Card. From now on, I will not use the term ALSA Device. Instead I will use the term ALSA "Physical" Device so as to be clear.
The main differences are:
- ALSA "Physicai" Device has an underlying physical device while the ALSA Virtual Device has none.
- ALSA "Physical" has a hardware address (0,0) or an alias name or both while ALSA Virtual Device has only an alias name.
Plugins are used to create ALSA virtual devices. Virtual Devices can be used like normal hardware devices but cause extra processing of the sound stream to take place.
Step 3: List the Auto-Built Virtual Devices of the Raspberry Pi
Without us lifting a finger, ALSA will auto-build a couple of virtual devices.
List all the ALSA "physical" devices and ALSA virtual devices.
Open terminal emulator:
aplay -L
The following are ALSA virtual devices:
dmix:CARD=ALSA,DEV=0
dmix:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=0
dsnoop:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=0
plughw:CARD=ALSA,DEV=1
The following are ALSA "physical" devices:
hw:CARD=ALSA,DEV=0
hw:CARD=ALSA,DEV=1
These 2 devices are real because they are described as "Direct hardware device without any conversions".
Step 4: Use an ALSA Plugin Called "route" to Create an ALSA Virtual Device
The ALSA plugin "route" is not used in any of the auto-built virtual devices. Therefore, I will have to give instructions to ALSA to create a virtual device that is built on the route plugin.
Create a file in /home/pi/.asoundrc
Open terminal
cd /home/pi
vi .asoundrc
Alternatively, use any text editor to create the file.
Write the instructions as shown in the screen shot.
Save the file.
ALSA will read the instructions and create a virtual device.
Step 5: List the New ALSA Virtual Device
Open terminal
aplay -L
The virtual device called "speaker swap" appears in the list as shown in the screenshot.
Step 6: Test the Virtual Device
Open terminal
First do a normal speaker test using the ALSA physical device:
speaker-test -D"hw:0,0" -c2 -twav
Then do it with ALSA Virtual Device called "speaker_swap"
speaker-test -Dspeaker_swap -c2 -twav
The Right speaker should output words "FRONT RIGHT".
The Left speaker should output "FRONT LEFT".
