Introduction: Morse Code With Arduino+LED
Hi,
I don't know the real reason, but I have that crush on the old technology and its stuff , one of the most thing I ever loved is morse code and how they communicate, so in my first days with arduino -three years ago I think !- one of my first projects was morse code with it, then I decided to try another method to use this codes, so I came with the LED idea in that night and did it.
Now in my very first instructable I'll write about this old MEMORY :)
Step 1: What Will Need!
Nothing just any Arduino board and LED
and some knowledge about the morse code https://en.wikipedia.org/wiki/Morse_code
you need to install arduino IDE and the drivers to communicate with the board
you can download it from this link >>>>> https://www.arduino.cc/en/Main/Software
that's it lets start fun :)
oh!...ONE LAST THING!!!
the morse code reference>>>> https://upload.wikimedia.org/wikipedia/commons/thumb/b/b5/International_Morse_Code.svg/2000px-International_Morse_Code.svg.png
Step 2: Programming....
before I start you need to that the programming is a fun thing just you need to get the right mode :)
now go and take a TRIPLE ESPRESSO
cause the code is easy but tricky (very!) -if you prefer to test the code or too lazy to write it my code files is attached just compile and upload it!-
all done lets start :
- first we need to but the LED in it's right place so but the taller part in the 13 pin and the shorter in GND pin like th pics.
- now all is ready connect the arduino to the computer and lunch the arduino IDE -don't forget to select the port-
- it's programming time :D,,,,,
to start programming u need first to download the reference to know the codes, this is some explanation and how we will do it with arduino :
-now u need to understand some points
-the dot and the dash, the dot is the short sound in morse code and the dash is the long one I made the time for the dot is 300 millisecond and 900 for the dash cause the dash is triple dot.
-u will find the time and the length of the morse code in the reference pic, maybe u will find the time I but different in some situation if u did please post and I'll explain.
-the code...............
//morse_code by LED
/* This code was written by Ebrahim Bawazir in 2013 and updated in 2015 U R FREE TO USE IT AND MODIFY IT AS U WANT ***************** */ int led =13;//the led pin char input;// to save the input void setup () { pinMode (led,OUTPUT);//tell that the 13 pin is an output Serial.begin(9600);//for the connect with the boared }void loop () { if (Serial.available()) { input = Serial.read();//read the input if (input == 'a' || input == 'A') {lA();}//if the input is a or A go to function lA if (input == 'b' || input == 'B') {lB();}//same but with b letter if (input == 'c' || input == 'C') {lC();} if (input == 'd' || input == 'D') {lD();} if (input == 'e' || input == 'E') {lE();} if (input == 'f' || input == 'F') {lF();} if (input == 'g' || input == 'G') {lG();} if (input == 'h' || input == 'H') {lH();} if (input == 'i' || input == 'I') {lI();} if (input == 'j' || input == 'J') {lJ();} if (input == 'k' || input == 'K') {lK();} if (input == 'l' || input == 'L') {lL();} if (input == 'm' || input == 'M') {lM();} if (input == 'n' || input == 'N') {lN();} if (input == 'o' || input == 'O') {lO();} if (input == 'p' || input == 'P') {lP();} if (input == 'q' || input == 'Q') {lQ();} if (input == 'r' || input == 'R') {lR();} if (input == 's' || input == 'S') {lS();} if (input == 't' || input == 'T') {lT();} if (input == 'u' || input == 'U') {lU();} if (input == 'v' || input == 'V') {lV();} if (input == 'w' || input == 'W') {lW();} if (input == 'x' || input == 'X') {lX();} if (input == 'y' || input == 'Y') {lY();} if (input == 'z' || input == 'Z') {lZ();} if (input == '1') {n1();}// the numbers if (input == '2') {n2();} if (input == '3') {n3();} if (input == '4') {n4();} if (input == '5') {n5();} if (input == '6') {n6();} if (input == '7') {n7();} if (input == '8') {n8();} if (input == '9') {n9();} if (input == '0') {n0();} if (input == ' ') {space();}//the space Serial.println (input);//print the latter saved in the input var } } //fonctions for the letters and the numbers void lA () {dot();dash();shortspace();}//letter A in morse code! void lB () {dash();dot();dot();dot();shortspace();}//same for B void lC () {dash();dot();dash();dot();shortspace();} void lD () {dash();dot();dot();shortspace();} void lE () {dot();shortspace();} void lF () {dot();dot();dash();dot();shortspace();} void lG () {dash();dash();dot();shortspace();} void lH () {dot();dot();dot();dot();shortspace();} void lI () {dot();dot();shortspace();} void lJ () {dot();dash();dash();dash();shortspace();} void lK () {dash();dot();dash();shortspace();} void lL () {dot();dash();dot();dot();shortspace();} void lM () {dash();dash();shortspace();} void lN () {dash();dot();shortspace();} void lO () {dash();dash();dash();shortspace();} void lP () {dot();dash();dash();dot();shortspace();} void lQ () {dash();dash();dot();dash();shortspace();} void lR () {dot();dash();dot();shortspace();} void lS () {dot();dot();dot();shortspace();} void lT () {dash();shortspace();} void lU () {dot();dot();dash();shortspace();} void lV () {dot();dot();dot();dash();shortspace();} void lW () {dot();dash();dash();shortspace();} void lX () {dash();dot();dot();dash();shortspace();} void lY () {dash();dot();dash();dash();shortspace();} void lZ () {dash();dash();dot();dot();shortspace();} void n1 () {dot();dash();dash();dash();dash();shortspace();}//number 1 in morse code void n2 () {dot();dot();dash();dash();dash();shortspace();} void n3 () {dot();dot();dot();dash();dash();shortspace();} void n4 () {dot();dot();dot();dot();dash();shortspace();} void n5 () {dot();dot();dot();dot();dot();shortspace();} void n6 () {dash();dot();dot();dot();dot();shortspace();} void n7 () {dash();dash();dot();dot();dot();shortspace();} void n8 () {dash();dash();dash();dot();dot();shortspace();} void n9 () {dash();dash();dash();dash();dot();shortspace();} void n0 () {dash();dash();dash();dash();dash();shortspace();} void space () {delay (1200);}//space between words void dot () {digitalWrite(led,HIGH); delay (300); digitalWrite(led,LOW); delay (300);}//the dot this code make the led on for 300 than off for 300 void dash () {digitalWrite(led,HIGH); delay (900); digitalWrite(led,LOW); delay (300);}//the dash this code make the led on for 900 than off for 300 void shortspace () {delay(600);}//space between letters /*done*/
any Q ask and I'll respond.
Step 3: Test the Code and Have FUN
if U read this than congrats U've done it
now have fun>>>>>>> xD
I hope u enjoyed with my memories and loved the project
ANY Q ARE WELCOME.............
done!
