Motion Decting Nerf Gun
Introduction: Motion Decting Nerf Gun
About: I love Raspberry pi, Nerf, Minecraft, 3D printing, and raspberry pie😁.
Hi! I'm Cameron. For this Instructable I show you how to make a motion activated Nerf gun. It is somewhat hard, but 100% AWESOME!!!
Supplies:
1. electric Nerf gun
2. Raspberry Pi (b+ and newer)
3. Battery Bank (2 amp and above)
4. PIR module (5 volts)
5. relay (I used a Songle SRD-05VDC-SL-C)
6. bits and pieces (breadboard, jumper wires, micro sd card, etc)
Teacher Notes
Step 1: Unscrew the Gun
This step is probably the simplest thing in this instructable. Just unscrew all the screws (outside only!).
Step 2: Remove the Battery Pack
This step was annoyingly hard on my Nerf gun. Remove all the screws and or glue.
Step 3: Attach the Battery Pack From the Nerf Gun
Simple! Hook up the negative side of the battery pack to the negative wire on the Nerf gun, then the positive to the center of your relay (it's the center on mine, but you will want to double check to make sure).
Step 4: Attach the MOTORS!!
Attach the positive wire(s) of the Nerf gun to the NO (Normally Open) part of the relay (mine was the right side).
Step 5: Attach the Relay
Hook up the data pin of the relay to GPIO 21 (bottom right) on the Raspberry Pi, GND up to Ground, and 5V to 5V.
Step 6: Hook Up the PIR
Hook up the data pin on the PIR to GPIO pin 4, GND to Ground, and finally 5V to 5V.
Step 7: Code It With Python
############################Here's the code!#################################
print ("Welcome!)
print ("Importing modules...")
from gpiozero import MotionSensor
import RPi.GPIO as GPIO
from time import sleep
sleep(0.2)
print ("Complete!)
print ("Setting up GPIO...")
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM
GPIO.setup(21, GPIO.OUT)
sleep(0.3)
print ("Complete!!")
sleep(0.1)
print ("Please wait for PIR to settle...")
pir.wait_for_no_motion
sleep(1)
print ("settled!")
while True:
	print ("Ready to fire...")
	pir.wait_for_motion()
	print ("Motion detected!!!")
	print ("FIRE!!!")
	GPIO.output(21, True)
	sleep(1)print ("Powering off")
	GPIO.output(21, False)
Step 8: Turn It On!
Steps:
1. tie the trigger with rope so it's is stuck to the on position
2. run the Python code
3. sprint away... OR GET SHOT!!!
I hope you enjoyed this Instructable, bye!
-Cameron
Reuse Contest
Reuse Contest
1 Person Made This Project!
  • Magnets Challenge
    Magnets Challenge
  • Raspberry Pi Contest 2020
  • Wearables Contest
    Wearables Contest
Computer Kid
Computer Kid
Tip 6 weeks ago
Put the PIR inside a paper towel role and point it at the area you want to detect motion in (-:
