Motorized, Articulated T Rex(ish) Pin Walker
11,759
135
18
About: The more mistakes I make, the more knowledge I gain.
"It don't mean a thing if it ain't got that swing (Doo wah, doo wah, doo wah, doo wah, doo wah, doo wah...)" Sorry, an old song (Duke Ellington, 1943) came to mind while designing this model...
Anyway, "Motorized, Articulated T Rex(ish) Pin Walker" is yet another pin walker design, this time featuring an articulated T Rex styled body that swings from side to side as the model walks along. And while paleontologists around the world will tell you this model does not accurately represent the walking motion of a T Rex, I'm old enough to have actually seen one, and yes it does..., uhh, ok, well no I'm not and no it doesn't, but it was fun designing this model anyway.
The model is designed to swing the articulated T Rex body ("Body.stl") at +- 8 degrees with a rotational a velocity sufficient enough to cause full swing articulation of the 3D printed in place body.
As usual, I probably forgot a file or two or who knows what else, so if you have any questions, please do not hesitate to ask as I do make plenty of mistakes.
Designed using Autodesk Fusion 360, sliced using Cura 4.3.0, and printed in PLA on an Ultimaker 2+ Extended, an Ultimaker 3 Extended, and an Ultimaker S5.
One final note, I receive no compensation in any form whatsoever for the design, equipment, parts and/or materials used in this model.
Supplies:
I used the following supplies:
  • Light machine oil.
  • Solder.
  • Double sided tape.
Teacher Notes
Step 1: Purchase, Print and Prepare the Parts.
This model uses the following non-3D printed parts:
  • One 3.7vdc 100ma Lithium Battery (https://www.adafruit.com/product/1570).
  • One JST PH 2-Pin Cable (https://www.adafruit.com/product/3814).
  • One N20 6VDC 100RPM gear motor.
  • One micro switch (Uxcell a12013100ux0116 High Knob 3P 2 Position 1P2T SPDT Vertical Slide Switch, 0.5 Amp, 50V DC, 50 Piece, 3 mm).
You will also need a suitable battery charger.
I printed one "Base.stl" at .2mm layer height (I'm printing one right now at .15mm layer height because the photographs of the .2mm model included in this Instructable were, well, quite awful), 20% infill with supports. I printed the following parts at .15mm layer height, 20% infill with no supports:
  • One "Arm, Left.stl".
  • One "Arm, Right.stl".
  • Two "Axle, Leg.stl".
  • One "Body.stl" (make sure your 3D printer does not over extrude when printing this part).
  • Seven "Bolt.stl".
  • One "Cam And Axle.stl".
  • One "Cam.stl".
  • One "Feet.stl".
  • One "Gear, Crown, Axle.stl".
  • One "Gear, Crown, Motor.stl".
  • Two "Mount, Body.stl".
  • Two "Pin.stl".
  • One "Seesaw.stl".
This is a high precision print (see photograph of "Body.stl" at about 1/3 through the 3D printing process) and assembly using at times very small precision 3D printed parts in very tight spaces. Prior to assembly, test fit and trim, file, sand, etc. all parts as necessary for smooth movement of moving surfaces, and tight fit for non moving surfaces. Depending on you printer, your printer settings and the colors you chose, more or less trimming, filing and/or sanding may be required. Carefully file all edges that contacted the build plate to make absolutely certain that all build plate "ooze" is removed and that all edges are smooth. I used small jewelers files and plenty of patience to perform this step.
The model also uses threaded assembly, so I used a tap and die set (6mm by 1) for thread cleaning.
I used light machine oil for lubrication of the gears and axles.
Step 2: Wire and Install the Motor, Switch and JST Connector.
To wire the the motor, switch and JST connector, I performed the following steps:
  • Cut the wires on the JST connector to 40mm in length, then stripped and tinned the ends.
  • Soldered the black wire from the JST connector to the motor "-" terminal.
  • Soldered the red wire from the JST connector to one of the outside switch terminals.
  • Soldered the center switch terminal to the motor "+" terminal such that the switch was centered over the motor.
    After wiring, I connected the JST connector to the battery, operated the switch to turn the motor on and off, turned the switch off, then disconnected the battery.
    With wiring complete, I pressed the motor into the motor mount on "Base.stl" such that 3mm of the motor shaft extended above the motor gear plate.
    Step 3: Add the Gears, Cams and Axle.
    There are two holes on the top sides of the body assembly, one large, and one small. The larger hole is the model right side which will be useful in assembly the model components in this step and the steps that follow.
    To add the gears, cams and axle, I performed the following steps:
    • Pressed "Gear, Crown, Motor.stl" onto the motor shaft.
    • Slid "Cam And Axle.stl" partially into the large hole at the top right of the base assembly.
    • Positioned "Gear, Crown, Axle.stl" centered over the small hole in the base assembly.
    • Pressed the cam and axle through the gear and out the small hole at the top left of the base assembly.
    • Pressed "Cam.stl" onto the cam and axle 180 degrees out of phase with the cam and axle cam.
    At this point, I again connected the JST connector to the battery, turned the switch on, checked for smooth movement of the gears and cams, turned the switch off, then disconnected the battery.
    Step 4: Add the Pins.
    To add the pins, I performed the following steps:
    • Positioned one "Pin.stl" into the pin slot in the base assembly such that the seesaw driving pin faced forward.
    • Slid the pin ring over the cam.
    • Secured the pin in place with one "Axle, Leg.stl".
    I repeated this steps for the remaining pin and leg axle.
    At this point, I again connected the JST connector to the battery, turned the switch on, checked for smooth movement of the pins, turned the switch off, then disconnected the battery.
    Step 5: Add the Seesaw and Body Mounts.
    To add the seesaw and body mounts, I performed the following steps:
    • Manually rotated the motor gear until both seesaw driving pins were level.
    • Positioned "Seesaw.stl" onto the front of the base assembly over the lower threaded hole.
    • Secured the seesaw using one "Bolt.stl".
    • Positioned one "Mount, Body.stl" above the seesaw on the front of the assembly aligned with the upper threaded hole and the seesaw teeth then secured in place using one "Bolt.stl".
    • Positioned the remaining "Mount, Body.stl" over the upper threaded hole on the rear of the body assembly then secured in place using one "Bolt.stl".
    At this point, I again connected the JST connector to the battery, turned the switch on, checked for smooth movement of the seesaw and front body mount, turned the switch off, then disconnected the battery.
    Step 6: Add the Feet.
    To add the feet, I positioned them toes forward over the bottom of the base assembly, then completely pressed into position (watch out for the switch and wiring) until the bottom of the feet were flush with the bottom of the base assembly.
    Step 7: Final Assembly.
    For final assembly, I performed the following steps:
    • Using double sided tape, I secured the battery to the lower rear of the body assembly.
    • Pressed "Arm, Right.stl" into the hole on the right side of "Body.stl".
    • Pressed "Arm, Left.stl" into the hole on the left side of the body assembly.
    • Positioned the body assembly in the two body mounts, head forward.
    • Secured the body assembly to the base assembly using four "Bolt.stl".
    • Tucked the connectors and excess wiring between the feet.
    And last but not least, power it up and watch it walk! I tethered this model to a power supply with an in series ammeter and determined the current draw to average around 17MA, so this model should operate quite awhile using the specified battery before recharging is required.
    And that is how I printed and assembled Motorized, Articulated T Rex(ish) Pin Walker.
    I hope you enjoyed it!
    Robotics Contest
    Finalist in the
    Robotics Contest
    Be the First to Share
      • Instrument Contest
        Instrument Contest
      • Make it Glow Contest
      • STEM Contest
        STEM Contest
      18 Discussions
      Mudzify2000
      5 weeks ago
      Awesome design, I am more happy to see that you have made it in fusion 360, I don't know why.
      gzumwaltMudzify2000
      Reply 4 weeks ago
      Thank you, I'm glad you enjoyed it!
      While Fusion 360 does have a steeper learning curve, I was well worth the effort for me.
      Greg
      DonnaCohn
      Question 5 weeks ago
      OK, another question from me about this part of the instructions. The "Gear, Crown, Axle", and the "Cam" spin freely on the hex shaft of the "Cam And Axle". Could there be something wrong with the resolution of my prints? Should I just change the hole sizes? Or should I just use glue....rather not use glue. What do you think?
      gzumwaltDonnaCohn
      Answer 5 weeks ago
      Hi again DonnaCohn,
      I downloaded the pieces and printed them on two of my printers and they fit tight as they were designed to.
      So that means one of two things, either my 3D printers are over extruding for the color I used (white and green tend to over extrude on my printers thus I frequently decrease the flow rate for these colors), or your 3D printer is under extruding for the color you are using. So what I've done is increased the hexagonal shaft size of the "Cam And Axle.stl" component such that there is .1mm clearance between the hexagonal shaft and the hexagonal holes in "Cam.stl" and "Gear, Crown, Axle.stl", named the new component "Cam And Axle .1mm Tolerance.stl", and uploaded it here. Please try this new component and let me know how it works for you. If it does not solve the problem, I'll increase the hexagonal shaft for a .05mm clearance.
      Again, I'm truly sorry!
      Greg
      DonnaCohngzumwalt
      Reply 5 weeks ago
      Hi Greg,
      The "Cam And Axle .1mm Tolerance.stl" is an improvement, but I think .05 will be better. I tried importing the file into Fusion 360, but I am not experienced enough with the software to scale up the hex shaft myself. Please share the file - I am almost there! Meantime, I am just going to scale up the part a tiny bit in the slicer software.
      gzumwaltDonnaCohn
      Answer 5 weeks ago
      Hi DonnaCohn,
      You really shouldn't need glue, and I'm not sure exactly what is causing that problem. I'll download the pieces and it will take a few minutes to print them to see what I've done wrong. It sounds as if I've uploaded the wrong "Cam And Axle.stl" component.
      I'm very sorry!
      Greg
      DonnaCohn
      Question 6 weeks ago on Step 1
      This project looks great so I am working my way through printing the parts. But the file labeled "Axle, Leg.stl" looks the same as the bolt. Also confusing is the picture of all of the parts shows only 4 bolts, but the list says that 7 are needed. Please clarify - I really want to make this fun project. Thank you for posting it!
      1 answer
      gzumwaltDonnaCohn
      Answer 6 weeks ago
      Hi DonnaCohn,
      Yes, "Axle, Leg.stl" and "Bolt.stl" are both 6mm threaded, but "Axle, Leg.stl" has a 10mm head (to hold the pin slot in place), and "Bolt.stl" has only an 8mm thread.
      The picture does indeed show four bolts close to the back that are used to attach "Body.stl" to the two "Mount, Body.stl". The remaining three bolts in the photo are actually in the "Mount, Body.stl" (two) and "Seesaw.stl" (one) which are used to attach these three components to "Base.stl".
      I'm truly sorry for the confusion, and hope this helps. If not, feel free to ask and I'll do my best to answer!
      Greg
      Renega
      6 weeks ago
      Amazing little articulated T Rex!
      His movement is cute and he is walking!
      I've already printed a lot of your designs and moving things, they all work. I really like your designs and the detailed descriptions associated with them, illustrated with pictures, videos!
      I'll capture this for my grandchildren too!
      Thanks again for this cute moving little machine!
      Look forward to the wonderful new structures that I wish you good health in design and construction!
      gzumwaltRenega
      Reply 6 weeks ago
      Hi Renega,
      Thank you so very much for your kind words! As I responded to Penolopy, I enjoy designing, 3D printing and making these models for the smiles they bring to the faces of family, friends and followers!
      You are very welcome, and many thanks again!
      Greg
      MichałZ10
      6 weeks ago
      Hi, may i ask what software have you used for the 3d model design?
      gzumwaltMichałZ10
      Reply 6 weeks ago
      Hi MichalZ10,
      Autodesk Fusion 360, Personal use version.
      Greg
      gzumwaltquerry43
      Reply 6 weeks ago
      Hi querry43,
      I made six of these for the kids and grandkids, and me. I have the last one tethered to a power supply on my desk and I, as you, watch it all day!
      Greg
      Penolopy Bulnick
      6 weeks ago
      This is great! I'm just amazed at all the wonderful things you are able to design :)
      gzumwaltPenolopy Bulnick
      Reply 6 weeks ago
      Thank you very much Penolopy!
      Thanks again,
      Greg
