Introduction: Moveable Carport Garden
Growing plants is important. It is healthy, greening, improves air quality and is all-round good for you. But this can be tough if you live in a second floor apartment without a balcony. This Instructable will show you how I grew carrots in a carport, radishes from rubbish, and spinach from wasted space.
Step 1: Materials
I got the idea for my garden while I was walking around the industrial estate in which I work. I saw a bunch of poly-boy cages waiting to be thrown out. I borrowed a friends ute and grabbed a couple.
A poly-boy is a 1m x 1m x 1m plastic cube with a reinforcing cages around it. It is used in industry to hold and transport 1000L quantities of liquids. I removed the plastic insert and just took the cages.
You also might need:
Scrap wood
Castors (if you want to move it)
Some outdoor fabric (I used outdoor umbrellas I found on the side of the road)
Dirt & plants
Scrap wood
Dirt & plants
Step 2: Give It Some Wheels
I used some scrap wood to make corners for the cages. I cut them on a 45 degree angle so they did not hobble me as I walked around my garden. I screwed in 4 castors - two that swivel and two that do not (because they were cheaper).
The castors I used are a little small for the weight of the garden, I would recommend assuming the soil will weight the same as water (1 cubic centimeter of water = 1 mL = 1 gram).
To get the weight, measure the volume (length x width x height) of the soil in cm and divide it by 1000 to get the weight in kilograms AND the volume in Litres. Soil and compost are sold in litres so this is a handy number to have. Don't forget to divide this weight by the number of wheels to get the weight on each wheel.
If you are in an Imperial country, measure the volume in inches (length x width x height) and multiply by 0.03606 to give you the weight in pounds (lb). As to the volume - I'm sorry, I'm an engineer and even I find it confusing to use inches, pounds and gallons!
Step 3: Cut the Wood for the Base
I got some old sleepers left over from a fence at my parent's place.
I used a circular saw to cut a series of lines at the same depth as close together as I could. It was then easy to just knock out the slivers of wood with a hammer.
I did this to ensure the wood couldn't slide out - but in hindsight this is not strictly necessary.
Step 4: Chuck It All Together
Screw the castor planks to the bottom of the cages (do it better than I did though).
Place a couple of notched sleepers (or simply pieces of scrap wood) through the cage to support the soil.
Step 5: Line It!
I draped the discarded umbrella fabric over the wood and lined it with garbage bags to help prevent moisture loss. This can be a real problem in raised garden beds, so skip this plastic lining at your peril!
I did not add any drainage holes - I assumed that there would be enough gaps between the plastic bags to allow excess water to drip through.
Step 6: A Load of B.S.
Well, a mix of manures, compost and mushroom compost. I chose to buy my compost/manure mix, but it would be just as easy to take some unused dirt from a pool-dig or other earth-moving site provided you enrich it. The dirt from deep underground is only useful as a medium to hold the manure, compost, water and fertilizers you add to it.
Step 7: The Fun Part
Neaten the edges of the material - I used plastic ties, but this could be done with more finesse using twine or wire wrapped around the edges.
Plant your plants - Look up some of the great Square-Foot Gardening Instructables to get the most out of your plot.
Mulch - It's quite important for weed suppression, water retention and insulation for your plants.
And most importantly, enjoy it!
Extra Ideas to Try:I would like to cut holes in the side of the fabric and plant creeping & climbing plants which can climb around the outside without disturbing the top plants.
If you are in a cold climate, you could try enclosing this in the winter as a sessional green house.Have a look on Instructables, there are hundreds of space saving plant ideas.
Good luck and add any ideas you think might be interesting!
Step 8: Update!
I pulled some of young carrots that needed to be thinned out of the top of the bed and planted them in the side of the garden.
If this works, when the carrots are ready for harvest, I will replace them with something creeping like tomatoes and cucumbers as we come into spring!
Stay tuned.
Stay tuned.
