Introduction: Multi-Angle Magnetic Hand Saw Guide
Probably you will have seen several times cutting magnetic hand saw guides. But I dare to say that never one guide that allows you to make the cut in several angles.
Here I’m presenting the multi-angle magnetic hand saw guide that I hope you like it and share your comments about it.
It's an indispensable guide which will become a "must" in your workshop.
And if you like the video please Subscribe to my Youtube Channel
Forward, inscrutable!!
Step 1: Materials and Tools
Materials
- Sapele & haya wood (Fagus grandifolia)
- Disc Magnets (12mm x 3mm)
- Araldite adhesive
- 2 Zinc plated binding post screws (8mm x 4,5cm)
- Linseed Oil
Double-Sided Adhesive Tape
Tools
- Engineers Square
- Portable drill
- Drill Bit (12mm and 8mm)
- Stanley No 5 plane
- Rasp half round
- Bessey Kliklamp
- Sanding Paper grit 250
- Japanese Saw
- Pencil
- Veritas wheel marking gauge
- Screwdriver for slotted screws
- Sliding Bevel
- Safety Scraper
- Chisel
- Handmade Shooting Board
- Handmade Magnetic saw guide 90º
- Ruler
Step 2: Creating the First Main Piece
The project has 3 wooden pieces.
For the first main part I cut I piece of 14,5cm x 3cm x 2cm. I made it all with hand-tools as for me is very enriching and very important that this piece is fully square. For cutting it I used my Japanese saw and for smoothing my plane Stanley No.5.
Step 3: Preparing the 2 Other Pieces
Once the first main piece created, we can start with the other 2 pieces. For this, we have to mark the piece in other 2 equals. For the moment, they don't have to be necessarily the same, they can be approximate as later we will adjust them.
I made it with sapele wood but it can be done with any other you choose.
Step 4: Convert the 3 Pieces Into 1
Now we have to convert the 3 pieces into 1. For this, we will use double-sided adhesive tape joining the 3 pieces leaving the main one in the middle.
Once joint, I planed it making sure that the piece is completely square. I want to remark that maybe this is the most important part of the job, since the future cuttings will depend on the accuracy that we have worked in this phase.
Step 5: Drill the Holes
With a 8mm drill bit I made 2 holes at each end of the piece. It's very important to get a completely right hole, since these small details will make an exceptional final result.
Step 6: Round the Corners
I rounded the corners with a rasp half round. For this I used 2 washers as a guide and finally for a finer surface finish I used a sanding paper of grit 250.
Step 7: Separate the 3 Pieces
It's time to separate again the 3 pieces and for this I used a chisel and a safety scraper to remove the remaining adhesive.
Step 8: Continuing With the Main Piece
I mark and cut the main piece with a sliding bevel and then I make 5 holes with a 12mm drill bit and 3mm deep.
Once the holes done I use araldite adhesive for gluing the disc magnets.
Step 9: Last Stage and Assembly
I cover it with linseed oil for protecting and polishing the wood and finally I build it with 2 zinc plated binding post screws (8mm x 4,5cm).
And here is the result for an essential hand-tool for every woodworker.
