Introduction: Multi-Moded Hack-Cam Using Arduino
Well, this is my first post. I made something that will make my
summer productive but it took only 1 day to finish this project, from planning to coding and to fabricating. Luckily, almost half of materials I used are salvaged and some are just stocked in the corner waiting to be touched. Believe me or not, I spend nothing 'cause I'm a bit resourceful.
This project uses mainly Gizduino(Arduino Clone here in the Philippines), a cdr-king spy keychain(808 cam), ultrasonic distance sensor and a bunch of resistors, bright LEDs, buttons and wires.
You can find here how I hacked the spycam
https://www.instructables.com/id/Keychain-camera-wi...
and the Gizduino and distance sensor, you can find here
http://www.e-gizmo.com/KIT/categ/pmaster.php?dpag...
It has 3 modes, first is Normal mode where it act as normal digicam using the button as shutter. Second is Time-lapse mode where you can leave this device while continuously taking images with 3 seconds interval. And lastly, Auto modewhere it captures image when an object or human is detected with in 1 meter range.
Step 1: Materials
For the materials
You'll be needing an
Arduino
808 spy cam
Distance sensor
Battery
1k and 330R resistors 1/4W
Clear white LEDs
PCB
Push-button Switch
Red and Green LED
A Box or container
For the Tools
You should have
Pencils
Ruler
Long-Nose Plier
Side-Cutting Plier
Drill and drill bits
Multi-meter
Screw Driver
Soldering Iron and lead
Soldering Holder
etc.
Step 2: Start Hacking
Here is a helpful link on how you can hack this spy cam
The little PCB on the picture is where I made my circuit, 2 led indicators and limiting resistors. For the trigger switch, I just made a voltage-divider to make 3.3V or near to that voltage logic level. I use 1k and 330R resistors
Step 3: Drill and Holes
I will not be detailed on how I attached all the components for the sake that you might get a different container or components. You will be in your own and on how creative and resourceful you are.
The buttons connected to arduino has pull-down resistors, they will set the modes of your device. In selecting the mode, reset the device first(3rd switch) and select the preferred mode. For Normal Mode, do not press any button switch, for time-lapse mode, press and hold the first switch, and for auto mode, use the middle switch. At the setup function in arduino, after resetting, the indicator will blink 2 times and 1 last long blink until it went to main loop. Therefore, never release your finger until the last long blink or else it will read that you never press any switch.
You can use my codes to guide where to put all output and inputs.
Step 4: My Final OUTPUT
Some images are taken using our project
Here is how it works, unedited sounds. :)
First Mode- Normal
Second Mode- Time-lapse
Third Mode- Auto
Here is the link for my time-lapse sample
Applications:
Time-lapse photography
Capture Faces in your Door entrance
Auto-Selfie Cam
Spy-cam
Want more?
Android Tablet to Android PC Desktop
https://www.instructables.com/id/Android-tablet-to-...
Multi-Moded Hack-Cam using Arduino
Arduino Contest
Sensors Contest
