Introduction: Setup Raspberry Pi Without Monitor or Keyboard
NOOBS requires a monitor, keyboard and mouse, which adds ~$60 (USD) or more in cost. However, once Wi-Fi is working, these devices are no longer needed.
Every time I start a new Raspberry Pi project, I lug out the monitor, keyboard and mouse and find a place to set them up. After completing my third Raspberry Pi project, I thought there must be a better way.
This approach is a bit more advanced and uses a MacBook Pro instead of a monitor, keyboard and mouse. So, it saves $45 and takes up less space.
The goals of this project are to:
- Eliminate the need for a monitor, keyboard and mouse
- Document my way to setup RPi for future RPi Wi-Fi projects
- Create a standard micro SD card image so next time I can skip many of the steps
NOOBS (New Out of the Box Software) is the easiest way to setup Raspberry Pi (RPi).
Step 1: Gather Parts
I have found the parts below perform best in my applications. These parts are more expensive than contained in the usual starter kit.
Get parts and tools (prices in USD):
- MacBook Pro (a PC could be used)
- Raspberry Pi 2 Model B Element14 $35
- Panda 300n WiFi Adapter Amazon $16.99
- 5.2V 2.1A USB Power Adapter from Amazon $5.99
- Micro USB to USB cable 3ft from Amazon $4.69
- FTDI TTL-232R-RPI Serial to USB cable from Mouser $15
- Case from Amazon $6.99
- SanDisk Ultra 16 GB microSDHC Class 10 with Adapter (SDSQUAN-016G-G4A) from Amazon $8.99
NOOBS uses 8GB, micro SD card, Class 6.
- Raspberry Pi Micro SD Cards
- RPi.org SD Card Benchmarks
- elinux.org to micro SD Card benchmarks
- Link to Raspberry Pi micro SD card guidelines
- Link to Raspberry Pi compatible micro SD Cards
Notes:
- Text enclosed in spades, such as, ♣replace-this♣, should be replaced with an actual value. Of course, remove the spades.
Step 2: Download Raspbian
Download Raspian
- If you previously created a standard image in Step 12, then skip this step and go to Step 3.
- Download latest full version of raspbian
- When this was last updated the latest version was: 2017-04-10-raspbian-jessie.zip
- Move the zip file from downloads to a directory where you store images:
♣your-macbook-image-directory♣
- Use an unzip utility to unzip zip file.
- Rename the image so it doesn't contain parentheses or spaces.
Step 3: Burn Raspbian Image to Micro SD Card
The directions for this step have been greatly simplified. The Appendix: Updates contains the original instructions.
Download Etcher
Follow the directions to install Etcher
Launch the Etcher app (On Mac, select Finder, New File Window, Applications, scroll to etcher and open). I use Etcher all the time so I pinned to the Dock). Etcher has three steps:
- Select a raspbian image
- Select a disk
- Flash
For whatever reason, when etcher completes it says the disk is unmounted, but if I take it out I get a message saying the disk was not properly dismounted.
I haven't seen any downside from this, but if you want to do it correctly, run the following and find the SD disk number:
$ diskutil list
Unmount your SD card by using:
$ diskutil unmountDisk /dev/disk♣micro-SD-card-disk#♣
Remove SD adapter from MacBook and remove micro SD card from adapter
Insert micro SD Card in Raspberry Pi
Step 4: Raspberry Pi Setup and Connections
Heat Sink
Remove tape and press firmly on to processor. The heat sink and chip are almost the same size. It was fairly obvious were it was supposed to go. I did not take a picture.
Case
Take case apart. The older version has three parts: top, bottom and middle. Slide Raspberry Pi into bottom part of case Slide Raspberry Pi into bottom. There are two clips on the end where the SD card is inserted. The board must slide under these clips. It slides in easily, no need to force it. Again, this seemed very straightforward. So, there is no photo. It is good to keep the pi in the bottom part of the case.
Cables and SD Card
Insert these into Raspberry Pi
- Micro SD card
- Ethernet cable
- Wi-Fi dongle
- USB serial I/O cable (see images above)
- Ground = Black wire, pin 06 on RPi
- Tx = Yellow wire, pin 08
- Rx = Red wire, pin10
Once the above are complete:
- Insert power cable
Insert USB/Serial cable into MacBook USB port
If using a standard raspbian image previously created in Step 12, skip to Step 9
Step 5: Determine USB Port
Determine USB Port being used by USB-Serial adapter. My MacBook uses a chip from FTDI.
Open terminal window
There are a lot of devices in /dev. Use this command to identify the device:
$ ls /dev/tty.* /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbserial-FT9314WH
Here is an alternate way to discover:
$ ls /dev | grep FT | grep tty tty.usbserial-FT9314WH
If neither of the above work, then try this:
Insert USB cable into MacBook, and run:
$ ls /dev | grep tty
Unplug USB cable, wait a few seconds and run:
Identify the differences
Step 6: Open Terminal Window and Connect to Raspberry Pi
Connect MacBook to Raspberry Pi using serial cable.
If you have a monitor connected, the raspberry pi will start in desktop mode.
On MacBook, open terminal window. See the image above and set up the terminal window preferences.
- Terminal, select Preferences, click Advanced tab
- xterm and vt100 work, but ansi works better when using nano
- Set Western ASCII instead of unicode (UTF-8))
In a terminal window enter:
$ screen /dev/tty.usbserial-FT9314WH 115200
Using terminal window on MacBook, login ito RPi: username = pi password = raspberry
Note: the USB-serial cable can drop characters. If characters are dropped you may not get a prompt, press Return or enter username and press Enter.
If recovery mode appears, then micro SD card is not set up correctly. Start over.
- The prompt for recovery mode is #
- Raspbian's normal prompt is $.
- NOOBS recovery login and password is: root and raspberry
Step 7: Setup Using Raspi-config
Setup raspbian using raspi-config
$ sudo raspi-config
- Expand Filesystem
- And reboot (tab to Finish and hit Enter) and reboot
$ sudo raspi-config
Change user password to:
♣raspberry-pi-password♣
Internalization Options
- * indicates selected
- Use spacebar to toggle *
- For the US, change locale unclick GB (using space bar) and click US English UTF 8 (en_US.UTF-8 UTF-8)
- Click OK, select UTF and click OK
$ sudo reboot
When the MacBook terminal window gets messed up:
- Close the terminal window (close all terminal windows and exit terminal app)
- Unplug the USB cable from MacBook
- Wait a few seconds and plug the USB cable back in
- Start a new terminal window and login
$ sudo apt-get update $ sudo apt-get upgrade $ sudo apt-get auto remove $ sudo reboot
Continue to setup raspbian
$ sudo raspi-config
- Change time zone US and Central
- Tab to Finish and reboot
$ sudo reboot $ sudo raspi-config
Advanced Options
- Change hostname to
- Enable SSH
- Finish
- Reboot
Step 8: Always Update and Upgrade
Wi-Fi isn’t working yet, so keep Ethernet cable plugged-in. Run the following commands
If there are errors, check that an Ethernet cable is plugged in.
Step 9: Setup Raspberry Pi WiFi
Setup wifi using this instructable:
Best USB WiFi Adapter and Setup for Raspberry Pi
If you are setting up a standard image, then wait until the end to create a pre-generated key and a certificate because these depend on the MAC of the Raspberry Pi.
A simplified view of WiFi setup is to run
$ sudo nano /etc/network/interfaces
and edit the file to look like:
#/etc/network/interfaces # settings. # Local auto lo iface lo inet loopback # Ethernet auto eth0 iface eth0 inet dhcp # Wifi auto wlan0 auto wlan0 allow-hotplug wlan0 iface wlan0 inet dhcp wpa-ssid "♣ssid♣" wpa-psk "♣ssid-password♣"
Step 10: Remove GUI
Optional step. My projects don't use a GUI, so remove it. Removing the GUI saves about 2MB of storage and improves performance.
$ sudo apt-get --purge remove 'x11-*' $ sudo apt-get --purge autoremove
Adding turbo mode has some wifi performance benefits. Edit the file:
$ sudo nano /boot/cmdline.txt
So it is:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes smsc95xx.turbo_mode=Y rootwait
Step 11: Setup Gmail
Mail is very useful for receiving notifications and alerts about issues on the Raspberry Pi.
Ensure repositories are up-to-date. Run the command:
Install SSMTP and mail utilities:
$ sudo apt-get install ssmtp $ sudo apt-get install mailutils
Edit the SSMTP configuration file:
$ sudo nano /etc/ssmtp/ssmtp.conf
as follows:
root=♣your-gmail-account♣@gmail.com mailhub=smtp.gmail.com:587 hostname=♣your-hostname♣ AuthUser=♣your-gmail-account♣@gmail.com AuthPass=♣your-gmail-password♣ UseSTARTTLS=YES
Edit the SSMTP aliases file:
$ sudo nano /etc/ssmtp/revaliases
Create one line for each user in your system that will be able to send emails. For example:
root:♣your-gmail-account♣@gmail.com:smtp.gmail.com:587
Set the permissions of the SSMTP configuration file:
$ sudo chmod 664 /etc/ssmtp/ssmtp.conf
Step 12: Find IP by Hostname
My home automation system needs to access my raspberry pis. However, DHCP allocated IP addresses can change. So, I tried assigning static IP addresses. I wasn't satisfied with this solution. Next, I tried using nmap to discover the IP address of a hostname, but this seem rather involved. I was going to set up a DNS server, when I ran across the solution below.
It is easier to refer to a raspberry pi by its ♣your-hostname♣.local.
Install multicast DNS.
$ sudo apt-get install avahi-daemon
Try pinging the device
$ ping ♣your-hostname♣.local
If you would like to change the hostname do the following, otherwise go to the next step
$ sudo nano /etc/hosts
The hostname should default to dietpi. Change the last line from dietpi to the new ♣hostname♣
192.168.1.100 ♣your-hostname♣
CTRL-O, CTR-X, ENTER to save and exit the editor
$ sudo nano /etc/hostname
♣your-hostname♣
Commit the changes to the system
$ sudo /etc/init.d/hostname.sh $ sudo reboot
Step 13: Backup the Micro SD Card
When Raspberry Pi is setup, then back up the image. Use this image to create the next project.
Also, backup the project when it is complete. If anything goes wrong with the SD card, then it is easy to restore it.
Shutdown the Raspberry Pi
$ sudo shutdown –h 0
Wait until the card has shutdown, and then remove the power supply, and then remove micro SD Card
Insert micro SD card into SD Adapter, and then insert the SD adapter into MacBook
On MacBook use these instructions from The Pi Hut with modifications as follows:
Change to directory containing raspbian image
$ cd ♣your-macbook-image-directory♣
Identify the disk (not partition) of your SD card e.g. disk4 (not disk4s1). From diskutil output, = 4
$ diskutil list
IMPORTANT: make sure you use the correct – if you enter the wrong , you will end up wiping out your hard disk!
Copy the image from your SD card. Ensure the image name and are correct:
$ sudo dd if=/dev/disk♣micro-SD-card-disk#♣ of=♣your-macbook-image-directory♣/SDCardBackup♣description♣.dmg
CTRL-t to see the status of the copying.
When complete, unmount the SD Card:
Instructable to convert dmg file to imge file
On the next project, use this image and skip many of the steps in this instructable.
And you are done!
Step 14: Appendix: Pre-generated Key
Pre-generated keys depend on the Raspberry Pi's MAC and are not unique to a micro SD card. These need to be setup for each device.
Create a pre-generated PSK key. Login to Raspberry Pi and run the command:
$ wpa_passphrase ♣your-ssid♣ ♣your-pass-phrase♣
output:
network={
ssid="♣your-ssid♣"
psk=♣your pre-generated key♣
}/etc/wpa_supplicant/wpa_supplicant.conf
Each parameter in the /etc/network/interfaces file was measured.
The wpa_supplicant.conf file must be correct or wifi won't work.
Login into raspberry pi and run the command:
$ sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Edit the file to look like this:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="♣your-ssid♣"
# use a pre-generated key
psk=♣your-pre-generated-key♣
# if creating a standard image for many projects, then use pass phrase
# instead of generated key
# a generated key depends on the Raspberry Pi's MAC
# psk="♣your pass phrase♣"
# specify for clarity
key_mgmt=wpa_psk
proto=rsn
# CCMP is the correct encryption to use for WPA-PSK
pairwise=CCMP
group=CCMP
}CTRL-o to write file
ENTER to confirm write
CTRL-x to exit nano editor
Step 15: Appendix: Add Client-side Certs to Web Servers
My projects are focused on home automation, and while it is useful for me to have access, I don't want the world to control my home. A server/client certificate pair prevents unauthorized users from accessing.
Follow this instructable to add certs: Restrict Access to Raspberry Pi Web Server
Step 16: Appendix: RSA Key Issue
While experimenting, I received the message below when I tried to login.
$ ssh pi@192.168.1.94
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY! Someone could be eavesdropping on you right now (man-in-the-middle attack)! It is also possible that a host key has just been changed. The fingerprint for the RSA key sent by the remote host is eb:98:60:31:52:ac:7b:80:8e:8f:41:64:c1:11:f9:ef. Please contact your system administrator. Add correct host key in /Users/jeffcartwright/.ssh/known_hosts to get rid of this message. Offending RSA key in /Users/♣your-username♣/.ssh/known_hosts:16 RSA host key for 192.168.1.94 has changed and you have requested strict checking. Host key verification failed.
There is an easy fix.
Open a MacBook terminal window and the vi editor
$ sudo vi /Users/♣your-username♣/.ssh/known_hosts
Login with you MacBook password.
The first entry is 1, press the down arrow key (16 - 1) until you are on the 192.168.1.94.
Type (delete line, write file , and quit):
dd :w! :q!
Now, login should work
If asked to continue connecting, confirm by typing yes.
The authenticity of host '192.168.1.94 (192.168.1.94)' can't be established. RSA key fingerprint is eb:98:60:31:52:ac:7b:80:8e:8f:41:64:c1:11:f9:ef. Are you sure you want to continue connecting (yes/no)? yes Warning: Permanently added '192.168.1.94' (RSA) to the list of known hosts.
Step 17: Appendix: Updates
11JUN2016
- Removed Appendix on static IPs
- Replaced with hostname.local
03JUN2017
- Updated Step 2 with latest raspbian directions
- Added Appendix: References
- Replaced Step 3, which read:
IMPORTANT: make sure you type in the correct disk number – if you enter the wrong disk number, you will wipe out your hard disk!
Insert a micro SD card into SD Adapter, and then insert the SD adapter into MacBook.
On MacBook use these instructions from Raspberry Pi. Summarized here:
- Open MacBook terminal window
- Change to directory containing raspbian image
- Identify the disk (not partition) of your SD card
- In this case, disk4 (not disk4s1) and = 4
- To identify your micro SD card, run the command:
$ diskutil list
- Unmount your SD card by using:
- Copy an image to your SD card. Ensure the image name and are correct.
- Use either the raspbian image or a standard image created previously in Step 12.
$ sudo dd bs=4M if=2015-11-21-raspbian-jessie.img of=/dev/rdisk ♣micro-SD-card-disk#♣
- CTRL-t to see the status of the copying.
- If there are errors, try different values for bs option, such as, 1m, 4m, or 1M. Larger Block Sizes (bs) are required for larger drives.
- When complete, unmount the SD Card:
- Remove SD adapter from MacBook and remove micro SD card from adapter
- Insert micro SD Card in Raspberry Pi
