Neo Steampunk Desk Clock
266
7
Steampunk because of the copper tubing.
Neo because of the modern Arduino.
Antisismic because of the springs holding the electronic pieces within the copper frame.
Step 1: Making the Copper Frame
This was the fun part part of the project.
I never made copper tube welding before that.
  • I tryied with my soldering iron : fail (not hot enough)
  • I tryied with a lighter : 1 success, many fails (not hot enough)
  • I bought a blowtorch at the DIY store : wow, works great
There are many videos on internet to teach how to weld.
The tricky part was welding the small rings in the corners.
Step 2: Making the Box
I used a few powertools to make the retro design.
I included plastic inlays (1mm thick) for the backlight led strip.
Magnets are included in the box to stick the upper part without screws.
Step 3: Making the Electric/electronic
This project involves high voltage (for the lamp) and low voltage for the Arduino.
The lamp bulbs are 25 Watts (220V). I used a On/Off switch and an intensity variator. The high voltage circuit is separate from the low voltage circuit.
I salvaged a power supply a 7.5 V adaptor. With a 7805 circuit, I generated 5V to power the neopixel ledstrip.
The Arduino Nano is directly powered by the 7.5 V. The 5V pin from the Arduino powers the realtime clock and the Oled screen.
Three buttons are used for choosing the led mode and display mode, as well as the time setting menu.
Step 4: Making the Arduino Circuits
I used three components :
  • Arduino Nano
  • DS3231 Real Time Clock
  • 1 inch OLED screen
I tried to have minimum visible wires. 4 wires are leaving from the Arduino (3 for the buttons, 1 for the led strip).
Step 5: Conclusion
It took me several weekends to make this project. It was great fun dealing with copper welding and designing the whole system. I like the global look of the lamp. It is not a full steampunk design though I think it is cool.
Hope you like it too and that it will inspire you.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    3 Discussions
    Brian clark
    Question 4 months ago
    Please can you upload the cod so that we can program the Arduino.
    Thank you for your help. Awesome Project
    From Brian Clark
    pejuda
    5 months ago
    <br><div></div>
    Por favor, puedes publicar el código. Gracias
    Matlek
    5 months ago
    Awesome project! I like how the circuit boards are hung between the copper tubes.
