Introduction: Nerf Dart Launcher for the FPV-Rover and FPV-Trike
From the beginning of building the FPV-Rover, I wanted to have a Nerf Dart Launcher on it.
And finally, here it is. This is the fifth upgrade for the rover and it won't be the last.
Videos:
Links to the Rover
Instructables: https://www.instructables.com/id/FPV-Rover-V20/
Thingiverse: https://www.thingiverse.com/thing:2952852
Links to the Trike
Instructables: https://www.instructables.com/id/RC-Trike-With-Re...
Thingiverse: https://www.thingiverse.com/thing:3669829
Follow me on Instagram for latest news
Step 1: Parts to Print
I've printed all parts from PLA, as nothing is critical on this one. ABS, PETG and all other materials would be fine as well.
Go to thingiverse for the most current versions.
1x servo cover
1x battery cover (with or without cutout)
1x dart feeder
1x esc bracket
1x armoured conduit
2x dart launcher
1x base plate (FPV-Rover or FPV-Trike)
1x top plate
1x servo arm extension
1x nerf dart storage
1x top cover
1x 18650 battery pack (if you want to use 18650 batteries like I do)
servo arm extension v1.0.stl
top plate v1.0.stl
dart launcher v1.0.stl
armoured conduit v1.0.stl
esc bracket v1.0.stl
dart feeder v1.0.stl
battery cover with cutout v1.0.stl
battery cover without cutout v1.0.stl
servo cover v1.0.stl
nerf dart storage v1.0.stl
top cover v1.0.stl
base plate trike v1.0.stl
base plate rover v1.0.stl
Step 2: Parts You Need (BOM)
Here is the list with all necessary parts for the Nerf Dart Launcher
2x Motor (take one clockwise and one counter-clockwise)
2x ESC
1x MG90 servo
100x Nerf Darts :-D
4x M3 x 10mm socket cap screws
2x M3 x 16mm socket cap screws
2x M3 nuts
1x M2 nut
1x 3S or 4S Battery (Optional. You can power it with the battery from the rover)
I do power the launcher with a 3S 18650 battery pack. for this you'll need
3x 18650 Battery + 1x Protection Board
Step 3: Mounting Parts to the Top Plate
To mount the parts together you'll need a screw driver and soldering station for the motors/esc.
Attach the 360degree servo, the two motors and the esc to the top plate.
Take care of the rotation of the motors. If they spin the wrong way, change two cables to the esc.
Step 4: Mounting Parts to the Bottom Plate
Attach the MG90 servo to the bottom plate using the screws came with. Take care of the right direction, otherwise the mechanism will not work. Don't attach the servo arm to the servo right now. Whait for the next steps.
Step 5: Servo Arm Extension and Nerf Dart Container
You need 8x 2mm x 12mm magnets to attach the top to the Nerf Dart container.
Beside the two screws, you'll need a 2mm x 12mm rod (or whatever with this dimension).
I used a carbon fiber rod I had from other builds.
Step 6: Dart Launcher and Armored Conduit
Attach the dart launcher to the motor. I used two motors with different directions, so that the screws won't come loose.
Step 7: Top Part and Bottom Part
Now it's time to attach the top part to the bottom part.
After doing this, you can screw the servo arm to the servo.
Step 8: Battery Pack
If you want to power your launcher with a battery pack of 16850 batteries, you have to print the battery adapter and solder the batteries to the protection board.
Step 9: Covers (servo and Battery)
Attach the covers for the servo and battery to the rest. Depending on what kind of battery you use, you can select between a cover with a cut out, or without.
