Introduction: How to Construct Houses With Plastic Bottles !!
Waste bottles for construction? Yes, it is difficult to think of a bottle as a brick. But a mud-filled bottle is as strong as a brick and whatever you can do with a brick, you can do with a bottle too..Plus it has got lots of advantages too...
This project was done as part of our college activity.The man behind this innovative idea is a german named Andreas Froese,who is also the founder of 'ECO-TEC' .
OFFICIAL WEBSITE : http://www.eco-tecnologia.com
About ECO-TEC
Building with Bottles :
This is an effective solution for reusing the plastic. Bottles have the following advantages over bricks and other construction materials.
1. Low cost - You know how much a bottle costs!
2. Non-Brittle - (Unlike bricks)
3. Absorbs abrupt shock loads - Since they are not brittle,there can take up heavy loads without failure.
4. Bio climatic
5. Re-usable
6. Less construction material
7. Easy to build
8. Green Construction
About ECO-TEC
- Found in 2001 by Andreas Froese Germen citizen and its head quarters is at Honduras Central America.
- ECO-TEC has done more than 50 eco friendly projects at Honduras, Columbia, Bolivia.
- ECO-TEC has experience working with Govt, Non-Govt and International organization.
- ECO-TEC has won lot of environmental awards for innovation.
- Developed technology to build with pet bottles which helps to reuse plastic bottles and avoid plastic menace.
- Developed technology to build water tanks with pet bottles.
4. Bio climatic
5. Re-usable
7. Easy to build
Step 1: Bottles,bottles Everywhere!
The video shows the strength of a mud filled plastic bottle.
When you make a clay brick, the time and energy used right from mixing the clay to baking it in the kiln and taking into account the firewood used for that, you will see that the bottle brick is far more energy-efficient.
The technology also reduces the carbon emission that happens during the baking of an ordinary brick . The heat generation from cement factories can also be reduced as this technology uses only five percent cement. The foundation for the entire construction is obtained from building waste and so the mountains from which granite is blasted out can be saved too..
PET Bottle can last as long as 300 years (undoubtedly longer than the cement used to bind the bottles together in the walls!).
The following picture is of an ecological house constructed in Honduras using some 8,000 PET bottles, in the process freeing up an estimated 12 cubic meters (m3) in the local landfill.
The house also features a living roof (sometimes called a green roof) of sod and turf. Such roofs not only have aesthetic appeal, but tend to insulate the house better than conventional roofs, lowering heating and cooling costs. They are also cheaper than conventional roofs.
When wet, the 102 square meter (m2), living roof of the casa ecol?can weigh as much as 30 metric tons (Mt, toneladas). The PET bottle walls can support the weight.
Step 2: Step I
This instructable tells you how to build a pavilion with these bottles.
1.Your first step is to collect as many discarded plastic bottles as you can..They can be of various capacities.
2.Next step is to find a place where you can get a hell load of dry sand (finer,the better).
3.Next process is to take the bottles, fill them with sand, sealed and then paste them with a mixture made of earth, clay, sawdust and a little cement to provide additional strength and durability.The following video shows how to fill the bottle.
4.Now you are all set.Always start with the pillar.You can have as many pillars as you want,but not less than 3.
5.Dig a cylindrical pit about 60cm in depth.The radius should be atleast 10cm more than the length of the bottle that you are going to use for constructing the pillar.
6.Make a cement bed(about 4cm thickness)in the pit.Insert an long iron/steel rod at the centre.Tie a long and strong thread to the rod. Now we are going to lay 10 or 11 bottles around this rod.For this,First lay a bottle on the bed such that the bottle is radially oriented towards the centre.(i.e.,the cap is oriented towards the rod).
7.Take the thread and make a knot around the neck of the bottle you just laid.Put the next bottle in similar way keeping in mind that the caps of the 2 bottles touch each other.Make a knot around the 2nd bottle also.Repeat the steps until you lay all the 11 bottles.You have made your first course of bottles.
8.Fill in the gaps between the bottles with rubble and cement.Make the next bed and continue this process till you fill the entire pit.Hurray!your foundation is complete.Leave it for a few hours so that the cement will solidify.
9.After you have made the foundation for all your pillars,you can start building the pillar.Lay the bottles like you did for the foundation,and you will see your pillars rising.You can put broken bricks or other construction wastes between the bottles so that they don't move.
10.Now if you want you can plaster your pillar with cement.This pillar is many times stronger much cheaper than an ordinary pillar made with bricks.
Step 3: STEP II
After building all the pillars,You are ready to make the platform.
1.Make an outline of your platform with chalk powder or any color powders.
2.Make a Clay bed about 5cm height and width=5 cm > length of the bottles.This bed runs along the perimetre of the platform.
3.Now lay the bottles (with their neck facing outwards )one by one on this bed and tie them to each other as shown in the picture.After laying a course , fill the inside area with cement,clay or rubble.If you want to make more courses,make sure that you knot each bottle of the underlying course with the above course as shown in the picture.This is to impart more strength to the structure.
4.This is your platform.Now put tiles or ceramics for flooring.
5.You can put any type of roof over this because the pillars are really strong enough to hold them.
6.Create your own designs ,and build your own structures with this cheap construction method !
Some structures (including residences,water tanks,seating etc)built with pet bottles are shown here
HAPPY BUILDING!! :D
HAPPY BUILDING!! :D
