New Raspberry Pi 4 USB 3.0 Personal Cloud With RAID Backup
Hello and welcome. Today we will be looking at how to build your very own
Cloud software system that will allow you to store your personal information in a cloud that you Control and maintain. This cloud will also employ a RAID 1 mirror so that you can have backup Hard Disk drives so that you data will not be lost if a drive should fail.
Supplies:
Links:
How to set up raspberry pi nextcloud server
https://pimylifeup.com/raspberry-pi-nextcloud-server/
How to set up software RAID 1 Mirror https://www.ricmedia.com/build-raspberry-pi3-raid-nas-server/amp/
MDADM RAID cheat sheet http://www.ducea.com/2009/03/08/mdadm-cheat-sheet/
Bill of Materials:
Raspberry pi 4 https://amzn.to/2GPc8jP
Micro SD card 16GB https://amzn.to/31ux1J1
External HDD 1TB external powered https://amzn.to/2YGiR5H
Teacher Notes
Step 1: The Setup of the PI
First you will need to install some software to get NextCloud going. Once you have flashed a good image onto a microSD card and inserted that into the pi you will need to connect both of the external hard disk drives to your pi on the USB 3.0 plugs. Then connect a keyboard to ti so you can configure things.
Then you will power up the pi and go to the top right of the screen and set up your wireless or wired internet to get an ip address.
Once that is done you will need to open up a terminal for the next step.
Step 2: Install Componants for Next Cloud
Next you will need to install some packages to get NextCloud up and running
Following commands in order
sudo apt-get update
sudo apt-get upgrade (if you do not have latest version of OS)
sudo apt-get install apache2
Once that is finished you will need to install all the PHP with the following command:
sudo apt-get install php7.3 php7.3-gd sqlite php7.3-sqlite3 php7.3-curl php7.3-zip php7.3-xml php7.3-mbstring
After that you will need to restart the apache2 web service to make the php stuff take effect
sudo service apache2 restart
Step 3: Install the Next Cloud Software
Next we will need to install the next cloud software so you will first need to change directories to the html directory
cd /var/www/html/
Now we need to go get the software and download and extract it to this location:
curl https://download.nextcloud.com/server/releases/nextcloud-10.0.3.tar.bz2 | sudo tar -jxv
We need create a folder to store the data in temporarily on the main memory card and also need to set permissions and owner/group
sudo mkdir -p /var/www/html/nextcloud/data
sudo chown -R www-data:www-data /var/www/html/nextcloud
sudo chmod 750 /var/www/html/nextcloud/data
Step 4: Finalize Your NextCloud Setup
Now you will need to finalize by creating a new admin user and password.
To do this you will need to go to your pi's ip address. If you do not know the address you can type the following in the terminal:
ipconfig
After gathering the IP address you will enter something like the following into either the chromium browser on the pi or on another web browser from a computer on the same network
http://192.168.1.28/nextcloud
Step 5: Setup RAID 1 Mirror
Now you will need to build your RAID volume from your two hard disk drives.
You should already have both HDD inserted into the USB3.0 ports of the Raspberry PI 4
First you will need to install the RAID software.
sudo apt-get install mdadm
Now we need to find out where the drive devices are so to do so you need to run the following command:
pi@raspberrypi:~ $ sudo blkid
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="3FFE-CDCA" TYPE="vfat" PARTUUID="80da4694-01" /dev/mmcblk0p2: LABEL="rootfs" UUID="3122c401-b3c6-4d27-8e0d-6708a7613aed" TYPE="ext4" PARTUUID="80da4694-02" /dev/sda1: UUID="76c0abd6-d547-3882-a94f-1bc4c78addf3" UUID_SUB="755aead2-13e8-04ed-d5f5-7f9805ae72b5" LABEL="raspberrypi:0" TYPE="linux_raid_member" PARTUUID="9b3ff72d-01" /dev/sdb1: UUID="76c0abd6-d547-3882-a94f-1bc4c78addf3" UUID_SUB="057c766c-556d-9c96-cb6c-b55d3721c4bf" LABEL="raspberrypi:0" TYPE="linux_raid_member" PARTUUID="cc00f35e-52e9-43b9-b955-33f4d54b203d" /dev/mmcblk0: PTUUID="80da4694" PTTYPE="dos" /dev/md0: UUID="94103a0c-0985-4d75-957f-042f4d9f3bd0" TYPE="ext4"
After this command is ran we see that the two drives are reccognized as the two devices:
/dev/sda1
/dev/sdb1
Next we will need to create the RAID volume (this will be a mirror where whatever is written to one drive is automatically copied to the other drive)
sudo mdadm --create --verbose /dev/md0 --level=mirror --raid-devices=2 /dev/sda1 /dev/sdb1
Now that the RAID array is created you can verify that with the following command:
cat /proc/mdstat/Personalities : [raid10]
md0 : active raid10 sdd1[3] sdc1[2] sdb1[1] sda1[0]
15319040 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
[>....................] resync = 0.4% (61504/15319040) finish=28.9min speed=8786K/sec
unused devices:
Now you will need to save your array creation by writing it to the mdadm configuration file with the following command:
sudo -i
mdadm --detail --scan >> /etc/mdadm/mdadm.conf
Then exit the root user by typing "exit" in the command window.
Now you will create the file system on your new RAID volume:
mkfs.ext4 -v -m .1 -b 4096 -E stride=32,stripe-width=64 /dev/md0
If successful you should see something like the following output:
1605632, 2654208
Allocating group tables: done Writing inode tables: done Creating journal (16384 blocks): done Writing superblocks and filesystem accounting information: done
Next we need to mount the newly formatted file system on the RAID volume with the following command:
sudo mount /dev/md0 /mnt
If you get no errors things are working properly now.
Finally in order to make sure your RAID volume is allways mounted at start up you will need to edit the fstab file with the following command:
cd /etc/
sudo vi fstab
Add the following line to the bottom:
/dev/md0	      /mnt	      ext4    defaults	        0	0
Save this with ":wq" and now when you reboot your pi it will automatically mount the /dev/md0 file system to the /mnt folder.
Step 6: Moving NextCloud Data Repo to New RAID Volume
Now we will need to move the data folder we created to the new RAID volume so it is backed up between the two hard drives.
We first need to make the directory structure on our RAID volume with the following command:
sudo mkdir -p /mnt/nextcloud
after that we need to move the data folder from the html folder over to the new nextcloud folder we just created:
sudo mv -v /var/www/html/nextcloud/data /mnt/nextcloud/data
Now we will need to tell NextCloud in it's config file where to find the new location.
To do this we need to edit with the following command:
cd /var/www/html/nextcloud/config/
sudo vi config.php
Now search within this file and find the following line:
'datadirectory' => '/var/www/html/nextcloud/data',
Change that to the following:
'datadirectory' => '/mnt/nextcloud/data',
Save your changes with " :wq "
Step 7: Increase the Max Upload
Now we need to increase the maximum upload since that is very small by default.
To do this we need to edit the php.ini file with the following commands:
sudo vi /etc/php/7.3/apache2/php.ini
find the two lines:
post_max_size = 8M
upload_max_filesize = 2M
And change them both to the following:
post_max_size = 2048M
upload_max_filesize = 2048M
This sets them both to 2GB. If you need more feel free to set them higher.
Finally restart the apache2 webservice to make changes take effect with the following command:
Step 8: Allow .htaccess Override in Prep for SSL SEC
To allow .htaccess to have override abilities to begin the process for securing your site you will need to edit the config file for apache2 with the following:
sudo vi /etc/apache2/apache2.conf
Find the section that looks like the following:
<Directory /var/www/>
     Options Indexes FollowSymLinks
     AllowOverride None
     Require all granted
</Directory>
Change the AllowOverride to the following:
     AllowOverride All
     Require all granted
</Directory>
Now you will need to restart apache2 web service to take effect:
Step 9: Setting Up SSL
Next we need to set up SSL so that we can have a self signed certificate for the https instead of http.
To begin we need the following commands to create the keys:
sudo mkdir -p /etc/apache2/ssl
sudo openssl req -x509 -nodes -days 365 -newkey rsa:4096 -keyout /etc/apache2/ssl/apache.key -out /etc/apache2/ssl/apache.crt
When the key builds there will be some information that you may want to fill out like the country and city but you do not have to fill out things like organizational unit, common name, or email address.
Once finished creating the keys you will need to enable the SSL module for apache wiht the following command:
sudo a2enmod ssl
Now we need to edit the config to use our keys we just created with the following commands:
sudo vi /etc/apache2/sites-available/default-ssl.conf
Within this file you will need to find the following two lines
SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
Change these to the following:
SSLCertificateFile /etc/apache2/ssl/apache.crt
SSLCertificateKeyFile /etc/apache2/ssl/apache.key
Now that is chagned we need to enable the defatult-ssl config as well as restart the apache2 web service to make all these changes take effect:
sudo a2ensite default-ssl.conf
Now you should be able to replace your http:// with https:// and get a secure connection using ssl certificates.
Bonus if you want to have the webpage redirect anyone that enters http instead of https you can do the following:
Open the 000 config file and add some lines as follows:
sudo vi /etc/apache2/sites-available/000-default.conf
Comment out everything in this file with a # sign and enter the following at the bottom of the file
<VirtualHost *:80>
     ServerAdmin example@example
     RewriteEngine On
     RewriteCond %{HTTPS} off
     RewriteRule ^(.*)$  https://%{HTTP_HOST}   [R=301,L]
</VirtualHost>
After adding this issue the two following commands to save it:
sudo a2enmod rewrite
Step 10: For Any Additional Inforamtion
If you would like additional information here are some great links and my video from my youtbue channel to help you out. Please consider coming by my channel and dropping a sub. I know you won't regret it.
Links:
How to set up a Raspberry Pi Nextcloud Server
https://pimylifeup.com/raspberry-pi-nextcloud-serv...
How to set up RAID on Raspberry pi
https://www.ricmedia.com/build-raspberry-pi3-raid-...
Try Amazon Prime 30-Days https://www.amazon.com/tryprimefree?ref_=assoc_tag_ph_1427739975520&_encoding=UTF8&camp=1789&creative=9325&linkCode=pf4&tag=misperry-20&linkId=3266ea72a7bf7fef009fd902c4fc81f8
Support the Channel and Become a Patron http://www.patreon.com/misperry
Check out the Channel Store https://www.tindie.com/stores/misperry/
Checkout the Forum!! https://groups.google.com/forum/#!forum/misperry
Support the channel tip with bitcoins Address: 1MvcZHRbDm9czS8s776iutBBPJ39K4PEHh
Follow me on Instructables https://www.instructables.com/member/misperry
Follow me on Facebook https://www.facebook.com/misperryee/
Follow me on Twitter http://www.twitter.com/misperryee
T-Shirts https://teespring.com/stores/misperry-channel-store
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    3 Discussions
    AronS25
    23 days ago
    Same as Carlos.
    I get the error, this version of nextcloud is not compatible with php7.1
    You are currently running 7.3.4-2
    carlos4computers
    Question 5 weeks ago
    Help please
