Introduction: Nitrogen Triiodide
About: Working wireless-ly.
Odds are that you've seen a demonstration of this stuff before, most likely in your high school chemistry class. It is a highly sensitive contact explosive made from two ingredients ammonia and iodine crystals. It is so sensitive when dry it can be set off by a feather or even a fly. The last time I made this was years ago for a science project. It was the middle of winter and I had been setting off batches of this stuff in my backyard all day. When night fell it started lightly snowing, the snow flakes fell to the ground and set off minute traces of the NI3. The resulting snaps were loud enough to wake up my mom who then woke me up and told me to do something about it. I wasnt really sure what to do about it so I filled up a bucket of water and threw it out over the pavement, setting off hundreds of little snaps which each gave off tiny poofs of purple smoke.
It has got to be one of the most surreal memories I have, being out in the moonlight while snowflakes gently floated down, causing the dead silence to be broken by little purple snaps going off everywhere.
Heres the wiki for it nitrogen triiodide
http://en.wikipedia.org/wiki/Nitrogen_triiodide
Step 1: Materials
Iodine crystals.
Can be bought on e-bay, unitednuclear.com, or http://shop.armorforensics.com/mm5/merchant.mvc?Screen=PROD&Store_Code=RedWop&Product_Code=1-2805&Category_Code=
That last one is a forensics website. Iodine crystals are used in a fingerprint lifting process called iodine fuming. As you can see on the label on the jar, the gas from the crystals has stained the paper to a dark purple color. Iodine gas is toxic, so do this experiment in a well ventilated area.
Ammonia
The purer the better. I use clear ammonia available almost anywhere. The store bought stuff is actually Ammonium hydroxide, meaning that it is ammonia dissolved in a ton of water. If for some reason you have access to highly concentrated ammonia the resulting nitrogen triiodide will be much more powerful, and therefore handled much more carefully.
A tupperware container
Coffee filters
Step 2: Mix It Up
Fill the container up with enough ammonia to completely submerge any crystals you put in. Spoon in the crystals, I highly recommend using a very small amount of crystals the first time (pencil eraser sized) so if you accidentally set it off you have less of a chance of injury.
Let the crystals sit for a few hours, I normally just leave them overnight and use them the next day. Overnight the nitrogen atoms from the ammonia will get it on with the iodine atoms and NI3 will result. I know what your thinking, nitrogen is a dirty for taking 3 iodine's at once, but who are you to judge, we've all done things were not proud of to make ends meet.
You, now have the extremely unstable compound NI3. It is relitavely safe to handle while it is still wet, but that is no guarantee of anything, it has been known to go off while still damp. So from this point on be very cautious around it.
Step 3: Filter It Out
Pour the ammonia container and iodine crystals through the coffee filter, and then quickly while it is still damp move the filtered crystals to where you want to set them off. It is not a good idea to do what I am doing in the picture and hold the coffee filter in your hand, I used water for the photos so it is not actual NI3 (it was raining outside, and I didnt want to have to deal with setting it off). Once the crystals are settled in their final resting place, wait for them to dry, which can vary from 30 min to a few hours. Use a long stick to set them off.
