Introduction: Old TSF Stereo Speaker
In this Instructable, I recycled an old TSF Radio from the 50's into a fully functional stereo speaker!
I found this Clarville Favori 55 in a garage sell nearby a week ago. I decided to open it to learn a bit more about this kind of electronic piece.
Now, I have an old-style looking speaker for my flat!
Step 1: Materials
For the build, you'll need some stuff:
- an Old Radio (obviously);
- some speakers ( I used two 5W sqarish speaker from an old tv, and two additional 3W speaker)
- an amplifier (I used the cheap DX0809 60W amp)
- a power supply (12V in my case)
- an AUX cable
- some wires
You'll also need these tools:
- a power drill
- some screwdrivers and pliers
- a hot-glue gun
- a soldering iron
Step 2: 1. Clean Up the Enclosure
First of, we need to take all the unnecessary components.
To do so, use everything you can think of. I used screwdrivers to remove all visible screws.
After that, I removed the lamps, cut the resistors.
Try to salvage as much stuff as you can. It might be helpful down the road.
For example, I salvaged the old golden dials.
I also removed the heavy and damaged speaker.
In the end, you should have and emplty but good looking wooden box.
Step 3: 2. Modify the Amplifier
To suit your needs, you 'll have to maybe make some changes to your amplifier.
I had one DX0809 laying around. It had 2 microphones jacks; a mic volume, treble and bass potentiometer.
I removed all of those components. I also desoldered the main volume potentiometer, to move it later on.
I also changed the sense of the Speaker entries, to suit the spot I put the amp in the next step.
Step 4: 3. Install the New Components
Now comes the time to assemble all components. I fixed the amp on the side of the box, with hot glue and small wood pieces.
I used the old dial and a potentiometer I salvaged earlier in the front. I just extended with wires, to the main board.
I also attached the two 5W speaker to the front of the box. I had two small 3W speaker to the bottom of the box, under the old metal electronics compartment.
After that, you can hook up the wires: positive and negative wires to each sockets, and in this case, the potentiometer.
Step 5: 4. Make the Back Panel
To make I used some thin plywood. I cut it to size and marked where I'll had to make the holes for the AUX cable and the power jack.
To do so, I used a jigsaw and a power drill.
Step 6: Conclusion
Okay, now, you should have a brand new, fully functional, vintage speaker!
Mine is quite loud and , as my opinion, looks good.
You can also had a bluetooth to 3.5 jack adapter and battery, to make it wireless.
Don't hesitate if you have any questions!
