Introduction: Our Bench
:) enjoy
Step 1: Pallet
First you just have to pick out the kind of pallet you want to use. We just chose a random pallet that we could find.
Step 2: Cut
The you want to take the pallet that you chose and cut the pallet directly in half. You can use a saw to do this.
Step 3: Attach
Then you attach the parts together. With this step you want to create the body of your bench. The body should look like the picture provided.
Step 4: Leg
You must then put the legs together and cut them in half. You will have pieces of wood from the pallet, you must take two and put them together like in the picture. Then you want to cut it in half.
Step 5: Legs Again
Then you attach the legs to the body of the bench. We did this one at a time using nails and hammering them into the body of the bench.
Step 6: Reinforce
This step is not needed, but if you want to make your bench as safe as possible, you should reinforce it by putting extra pieces of would under where you would sit on the bench like in the picture.
