How to make a quality PCB
I apologize for the photos of low resolution,
The home of two PRO camera. Both of the cameras my family had taken out of town
pcb preparation consists of several stages:
1. Prepare a PC program with EAGLE, Sprint-Layout, Proteus 8 Professional or any other kind of acceptable program
2.Print a printed file Print Screen Color Separation & Film Print for PCB
3.PCB Circuit Board Single / Double cut on size and cleaning
4.Draw the paint on it with Silk Screen Printing Mesh
5.It can be over 65 degrees, 25 minutes
6.Transparent paper Put the already dry PCB
7.UW Irradiate light 1 minute
8.Then place the iron (III) chloride FeCl3
Step 1: Prepare a PC Program With EAGLE, Sprint-Layout,
The Sprint-Layout work just because of beauty
It's easy to find other programs
Step 2: Print a Printed File Print Screen Color Separation & Film Print for PCB
In the nearest Print Center print a transprent paper PCB board
I cut it and inserted it to the other side of the panel
Its easy to fix with Soldering Iron
Step 3: PCB Circuit Board Single / Double Cut on Size and Cleaning
Step 4: Draw the Paint on It With Silk Screen Printing Mesh
PCB Circuit Board Double Sided Copper with clean alcohol
Step 5: It Can Be Over 65 Degrees, 25 Minutes
You can use all the ropes that control the temperature
The microwave does not work
Step 6: UV Irradiate Light 1 Minute
Wash with sodium hydroxide
Warning: Sodium hydroxide Harmful to health
Step 7: Then Place the Iron (III) Chloride FeCl
I'll try to provide you with more quality photos
2 Discussions
25 days ago
Nice pcb..how do you remove paint on solder pad?
Reply 25 days ago
Once again, PCB sodium hydroxide should be removed, all the paint is removed
After that it is painted again
To the right of the photo to transprent it should be used and again UV Irradiate Light 1 Minute
You must repeat the procedure
In this case I stopped because I liked the PCB because I had to light up the lights
Now I'll have to get rid of it by mechanical intervention :)
We will offer you complete instructions soon
