Introduction: Polythene Pipe Leak Repair
Step 1: Find the Leak
Find the leak and dig a hole. Once you have successfully found the leaking pipe, turn the water off at the water-main.
Step 2: Find the Leak in the Polythene Pipe
To find the leak in the pipe, just turn the water back on just a little and you will see the leak. Make a mark, then turn the water off again.
Step 3: Cut Out the Hole
Once you have located the hole cut the pipe in half at the hole. You will need to cut out a 10-15mm section out so the fitting will fit
Step 4: Put the Fitting in Place
Put the fitting in place and make sure that you put all the bits in the right place.
Step 5: Tighten It All Up
Once you have tightened it up, you are almost done - woohoo!
Step 6: Tip of the Day
As you can see there is a pool of water at the bottom, if you empty most of this out once you have finished and cover the hole until the next day this will help you see if the leak is fixed. If the hole fills up with water again...then the hole ain't fixed lol.
"Time to get a pro in"
Step 7: Oh Yeah - the Tools You Will Need
Pipe wrench
Crescent
Stanley knife
And a spade
Crescent
Stanley knife
And a spade
