Introduction: PVC Sukkah / Symbolic Wilderness Shelter
This Instructable describes how to build a PVC Sukkah (for the jewish holiday of Sukkot). It stores small in the off-season, and it assembles leisurely in about 3 hours by just one person.You could probably shave off as much as an hour with 2 people, and it may be sub-2-hours with 3 people.
Step 1: Assemble Parts and Tools
Piping (the first time you build this you'll have to cut the PVC piping to size). Alll pipe is 1.25"
- 7 x 10' PVC Pipe
- 5 x 8' PVC Pipe
- 1 x 7' PVC Pipe
Fittings
- 7 x 3-Way Elbow PVC Fitting, Furniture Grade, 1-1/4"
- 2 x 90 degree Elbow PVC Fitting, Furniture Grade, 1-1/4"
- 1 x Slip Tee PVC Fitting, Furniture Grade, 1-1/4"
Other
- 3 x 10' x 8' Canvas Tarps with grommets
- 2 x bags 6" Ball bungee
- 1 x spool jute twine (or similar)
- 3 x 10' Galvanized Metal Corner Bead (or similar)
- 2x 10'+ x 6' reed fencing
- 6+ Tent stakes + rope
Suppliers:
- Formufit fittings: either Amazon or Direct from formufit
- Canvas tarps and ball bungee: tarpsplus.com
- Twine, corner bead, 1.25" PVC pipe, reed fencing: home depot
Tools
- camping mallet
- pocket knife
- 6' ladder
Step 2: Assemble the Frame
There are different ways to assemble the frame, depending especially on how many people are helping. I'll explain how I assembled the sukkah alone, but you should use your best judgement.
N.B.: find the flattest plot of land you can
- Lay out the 3 x 10' sill pieces that set on the ground, and connect with 3 x 3-way fittings.
- Add the 1x 7' bottom sill piece. You will note it stops short creating a door way.
- Add elbows pointing upward so that they frame the doorway.
- Now Insert 3 of the upright 8' pieces.
- Build 1x 10' top length with a 3-way fitting on each end and 2x 10' top length with only 1 3-way fitting on the end.
- Insert the top 10' length into the back side of the Sukkah, then insert the remaining 2 lengths completing the top.
- Slip the slip-T on the final 10' top length, and set this 10' top length in the open 2x 3-way fittings.
- Insert the final 8' upright in the elbow and slip-T.
Use 2 lengths of corner bead across the top of the Sukkah to support the roof. The corner beads, as they are bent at 90 degrees, are very strong (when positioned pointing upward) and lightweight. There is probably a better solution, but this works.It's challenging to affix them with twine. A zip tie could be used instead; you'll have to figure this part out yourself.
Step 3: Affix the Canvas Walls
The bungee balls are fairly self explanatory - you will pass the bungee cord -folded over- through a grommet, then wrap the bungee loop over the ball.
- Connect the top of the tarp to the top PVC post first
- Connect the sides of the tarp to the PVC corners second.
Step 4: Cover the Sukkah With a Roof
I rolled over the reed-fence roof. This solution is good because it will store year to year, but you may use freshly cut branches for more authenticity.
Step 5: Stake the Sukkah to Earth
Stake the Sukkah just in case it gets windy - it will act as a sail otherwise. See the photographs for how I wrap string around the upper corners and then stake it to ground.
Now hang decorations and enjoy your temporary structure!
