Paper Turbine & Silhouette Projector Machine
Introduction: Paper Turbine & Silhouette Projector Machine
About: Self learner and father of three, nature lover.
Its from paper and it moves ! Its a Paper Machine right ?
What I most love about paper its their versatilty. We can create with paper a lot of machines, well this machine its moved with heat. and his motor its made of paper. This turbine receives the hot air from below and start to move until the heat its off.
I made a Silhouette Paper Lamp or a lampshade for my kids and it was a lot of fun.
Check this out this awesome piece
Step 1: Materials
Colorful paper
Shape scissors
Compass
Glue
Xacto Knife Kit
Needle
Spring Press Stud
UHU Glue
Ceramic Tile
Silhouette Cutter AKA Right Hand
Step 2: Paper Turbine
This paper turbine works with heat. When the cold air get inside the lamp it goes up pushing the fins and making a slight movement.
I just draw a circle with a 11 cms radius, and divided in 12 pieces cutted with the shape scissors, then I gave the shape of a dome sticking the fins with adhesive tape and finnally with glue. In the center I put a Spring Press Stud where its going to spin the whole structure.
Step 3: Silhouette Projector.
I used a piece of paper of 36cms x 15 cms. I draw simple shapes with chalk ,also my 6 yo son, then cutted with my xacto knife over the ceramic tile , finnally I glued the turbine and installed in my Silhouette Lamp.
There are infinite possibilities, you can make your favourite shapes
Step 4: Silhouette Lamp
I used this Turbine and Projector in my Silhouette Lamp. Check this out !
Let me know in the comments what more uses can I give to my Paper turbine.
And if you liked this you can vote in The Paper Contest
Paper Contest
Paper Contest
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    3 Discussions
    Mr.Sanchez
    Mr.Sanchez
    11 months ago
    With this simple project I have teached my students how thermodynamic forces works in an easy way. How to build from a single paper sheet a 3D structure that works as a propeller using the heat from the light bulb. It is simple for kids learn how to use a simple drawing compass and use maths to divide the circle in 8 or more pieces and use them as propellers.
    M.C. Langer
    M.C. Langer
    1 year ago
    Interesting project! Good luck!
    Mr.Sanchez
    Mr.Sanchez
    Reply 1 year ago
    Thanks Bro !
