Persona Project
3,696
32
5
Introduction: Persona Project
"Persona Project" electronic weareable device tag who can show your name for meetings, commercial presentations or funny messages for events.
  • Can show messages to your friend, customers, waiters, presentations
  • Loop messages
  • 3 type of diferent texts sizes: 4linesx16chars, 2x8 and 1x4
  • Text with flashes
  • Lightweight
  • You can wear it on your tie, shirt, pocket...
  • Very low power consumption
  • Can be powered with your phone directly, or an external powerbank.
  • Low cost
  • Easy to build
  • Easy mod for other power sources like Lipo battery or twin CR-2032
Supplies:
You need this supplies:
  • 3d printer with PLA filament
  • Solder
  • 4 x wires (red, yellow, green, black)
  • 1 x 0.91"OLED Display i2c type OLED
  • 1 x Digispark ATTINY85 Lilypad Nano Lilypad
Teacher Notes
Step 1: Print the Case
Print the case with 3d printer. Using PLA filament.
You can download my model from this TinkerCad url.
Step 2: Prepare Supplies
Cut wires about 4 inch (10 cm).
Is better idea to use silicon quality wires.
(note: the rule is in cm)
Step 3: Use Your Solder
Pay attention with wire colors and the order:
  • Green to pin "P0"
  • Yellow to pin "P2"
  • Red to pin "5V"
  • Black to pin "GND"
Step 4: Measure, Cut and Weld OLED Display
Cut wires and strip, weld cables same order and put covers to close the device
Step 5: Fold With Solder Heat
Close solder to middle of frontal cap and apply hot. Fold carefully. Don't overheat the PLA plastic. Be patient :)
Step 6: Upload Program With Arduino IDE
  • Unzip attached file PersonaProject.rar
  • Open Arduino IDE
  • Open the PersonaProject.ino file who is located into the PersonaProject folder
  • Set board to Digispark (default - 16.5mhz)
  • Compile&send
  • Enjoy
If need Digispark ATTiny85 Nano drivers or Arduino libraries,
Here driver
Here library
Plz, vote my instructable Wearables Contest 2020.
That's it !
Wearables Contest
This is an entry in the
Wearables Contest
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    5 Discussions
    smj56
    smj56
    Question 2 days ago on Introduction
    Really nice. Thinking about this for my high school CAD/Fabrication class. Question. What powers this? I do not see a battery?
    Dan_X3z
    Dan_X3z
    Answer 2 days ago
    Thaks. This device (digispark attiny85) is powered trogh micro USB connector. In one of my photos is powered with cheap black powerbank (2400mha, is the snaller powerbank i found) with a simple USB to microuse cable. I tested this device with that powerbank more than 24 hours working with this source code and the battery still charge. You can power with twice cr2032 batteries or lipo but im untested. The device housing can be made deeper for add 2 batteries cr2032. But repeat untested. i Attached photos
    Dan_X3z
    Dan_X3z
    Reply 2 days ago
    Cr2025 vs device Dize.
    Connectir usb
    smj56
    smj56
    Reply 1 day ago
    Thanks. It looks like there is a 5v and Vin and GR on that Lilypad. I have some 2032 batteries and holders. Bet it might work. I would have to reDesign the holder. Not that much of an issue.
    Dan_X3z
    Dan_X3z
    Reply 1 day ago
    Perfect. You can supply power trough VIN instead 5v. My goal was to do as easy as possible. Thats because i use that digispark device powered with a powerbank or phone with OTG cable. If you want redesing, think if you can use attiny85 chip directly (cheaper, snaller,..). Other point is the OLED. Its 3.3v to 5v but maybe have 6v tolerance?
