Photoresistor Sensor With Arduino Uno R3
About: PrimeRobotics is a E-Commerce site, which focus on supplying right products to Electronics Hobbyists, Enthusiast & Students.
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity; in other words, it exhibits photoconductivity. A photoresistor can be applied in light-sensitive detector circuits, and light- and dark-activated switching circuits.
Step 1: Components Required
Step 2: Principle
The resistance of the photoresistor changes with incident light intensity. If the incident light intensity is high, the resistance reduces; if low, increases.
In this experiment, we will use eight LEDs to indicate light intensity. The higher the light intensity is, the more the LED is lit. When the light intensity is high enough, all the LEDs will be lit. When there is no light, all the LEDs will go out.
Step 3: Schematic Diagram
Step 4: Procedures
Step1:
Build the Circuit
Step 2:
Download the code from https://github.com/primerobotics/Arduino
Step 3:
Upload the sketch to the Arduino Uno board
Click the Upload icon to upload the code to the control board. If "Done uploading" appears at the bottom of the window, it means the sketch has been successfully uploaded.
Now, if you shine the photoresistor with a certain light intensity, you will see several LEDs light up. If you increase the light intensity, you will see more LEDs light up. When you place it in dark environment, all the LEDs will go out.
Step 5: Code
* name:Photoresistor
* function: if you shine the photoresistor with a certain light intensity, you will see several LEDs light up.
* If you increase the light intensity, you will see more LEDs light up.
* When you place it in dark environment, all the LEDs will go out.
/Email: info@primerobotics.in
//Website: www.primerobotics.in
const int NbrLEDs = 8;//8 leds
const int ledPins[] = {5, 6, 7, 8, 9, 10, 11, 12};//8 leds attach to pin 5-12 respectively
const int photocellPin = A0; //photoresistor attach to A0
int sensorValue = 0; // value read from the sensor
int ledLevel = 0; // sensor value converted into LED 'bars'
void setup()
for (int led = 0; led < NbrLEDs; led++)
pinMode(ledPins[led], OUTPUT);// make all the LED pins outputs
void loop()
sensorValue = analogRead(photocellPin); //read the value of A0
ledLevel = map(sensorValue, 300, 1023, 0, NbrLEDs); // map to the number of LEDs
for (int led = 0; led < NbrLEDs; led++)//
if (led < ledLevel ) //When led is smaller than ledLevel, run the following code.
digitalWrite(ledPins[led], HIGH); // turn on pins less than the level
else
digitalWrite(ledPins[led],LOW); // turn off pins higher than
Step 6:
    • Remix Contest
      Remix Contest
    • Warm and Fuzzy Contest
    • Organization Contest
