Pipeline Inspection Robot
10,821
69
8
Introduction: Pipeline Inspection Robot
Pipeline systems deteriorate progressively over time through various means. Pipeline inspection robot are designed to remove the human factor from labour intensive or dangerous work environments and also to act in inaccessible environment. However, if you take a look at the prices of those robots you will find that they are way too expensive.
This project aims to create another kind of pipeline inspection robot. Because we think that It is beneficial to have a robot with an adaptable structure to the pipe diameter, and cheaper at the same time.
Our challenge is to make this robot adaptable to diameters varying from 260mm to 390mm based on two sliding mechanisms.
Bruface MechatronicsProject VUB/ULB/ERASMUS
Team Members:
Dushimyimana Christophe
Houban Houda
Khoulali Soumia
Martin Simon
Zhao Ziao
Step 1: Design
We started out by creating a basic design in CATIA V5. The robot consists of two separated sliding mechanisms fitted onto a PVC central tube. Each sliding mechanism has three legs fixed to a cylindrical collar and linked to the sliding cylinder by a small link.
To slide, a spring makes the extension and the compression movement possible. So if the legs are compressed, the robot's diameter decreases. Once this compression force is released, the robot extends automatically. In between the two mechanisms, there is a holder of the electronic components which is in the shape of a long collar.
In our design (shown in the images above), two front legs are controlled by two highly geared dc motors. the rear legs are without motors because the front ones are powerful enough to drive the whole mechanism.
Step 2: Tools and Materials
Microcontroller
  • 1xArduino Uno (any will work)
Motor Controller
  • 1x H-Bridge (L298N)
  • 22AWG Solid core wire
  • 220V SMD Rework Soldering Station
Power
  • 4x 9V Battery ( 1 to power the Arduino and 2 for the motors)
Other Electronics
  • 2x 12VDC motors
  • DPDT Toggle switch (Power switch)
  • SPDT Slide switch (User input)
  • Heat Shrink Tubing
Hardware
  • 6x laser cutted links (the motor links are slightly different from the other links)
  • 6x PLA small links (printed)
  • 2x Collars (printed)
  • 2x Translational elements(printed)
  • 1x Electronic parts holder (printed)
  • 2x Strong rectangular springs (printed)
  • 2x Motor-wheel pin (printed)
  • 4x Link-wheel pin (printed)
  • 2x bushing for motors (printed)
  • 4x 7mm bearings
  • 18x 3mm bolts
  • 7x 2.5mm bolts
  • 7x Zip ties
  • 6x robot tire plastic wheels
  • 1x end blocker
  • 14x 2.5mm pgp-fasteners
  • 36x 3mm nuts
  • 14x 2.5mm nuts
  • 50x 3mm shims
  • 1x 40mm PVC tube
Tools
  • Electric Drill / Drill press (As well as a lot of bits)
  • Laser cutter
  • 3D printer
  • Hacksaw
  • Soldering Iron
  • Pliers
  • Allen wrench
  • Assorted screwdrivers
  • Wire Strippers
  • C Clamp
  • Ruler
  • Multimeter
Step 3: Motor Controller
The motor controller that we built for this robot is based on an H-Bridge chip (L298N). With this chip, each motor requires two inputs to work (if one of the two pins of the H-bridge is HIGH and the other is LOW, then the motor will turn, but if it's inversed, the motor will turn in the opposite direction ! ).
Now you need to control the exact velocity of these motors. You can do this by putting a lower voltage on the "HIGH" pin of the Arduino knowing that any voltage higher than 5V will give the same motor velocity.
After fixing all the electronic components in the holder, we solder them in place and make connections using 22AWG solid core wires.
Step 4: Power
To power the Arduino, a 9V stack is used. It has a common ground with the three in series 9V stacks.
To power the H-bridge and the motors, 3x 9V stacks are used in series which provide a source of 27V.
Step 5: Legs
The legs are some of the most important parts of this robot because their design determines whether or not they can support the weight of the motor and the pressure due to the pipe. We decided to have 2 legs out of 6 controlled by one motor each, and the other 4 legs use roller bearings to have low friction.
To make the legs we laser cut a 6 mm width wood plate. As you can notice from the above images, there are two different cuts for the legs, this is due to the fact that one cut is for the motor-driven legs and the other is for the normal legs.
Step 6: Building Frame
With the legs finished, the next step is to build a frame to hold the motors and legs in place. We start the frame by making a suitable pin/bushing(in white) to hold the motor, the leg and the wheel together.
In order to fix the motor to the leg, we use 2 screws that enter from the whole of the leg through the holes of the motor, also we use a zip tie to fix it even more.
In addition to that, we use a pin to connect the motor shaft to the wheel. To reduce the friction between the wood and plastic, we fix a bushing in the leg central hole. After that, we make a pin (in black) for linking the normal leg to the wheel.
In order to ensure free rotation of the wheel, we put a roller bearing inside the leg so that the pin can rotate freely with the wheel. Then we bolt the legs through the collar with washers and locknut to hold them in place and let them spin freely on the bolt. we do the same thing for the fixation of the small link (in white connected to the legs) with the translational element and the leg. Finally, we bolt the collars to make sure that they are fixed to the central tube.
Step 7: Electronic Platform
We have designed the holder in order to fix all the electronic components easier. there is a place for Arduino ship and also in the opposite sides a place for H-briges, baterries and switches.
Finally, we screwed the Arduino and motor controller into the holder and we use the zip ties to fix the switches and the batteries.
Step 8: Wiring the Robot
The next step is to wire all the electrical components of the robot together. We start out by soldering long wires to the contacts on the motors. Next, wire together the pots on the legs. This is done by using segments of ribbon cable from an old IDE cable. The pots are wired so that they all have a common ground and input voltage. The input voltage is connected to the +9V pin on the Arduino, and the two signal wires are soldered to headers and then connected to analog inputs A0 - A1 on the Arduino.
Next, we wire the digital output pins on the Arduino to the inputs on the motor controller.
Finally, we drill a hole in the central tube so that we can enter the cables into the tube until the open end of the tube, where we fixed the front legs. This is done to connect the motors easier. Then we connect each motor voltage terminal to the 9V battery pack, via a toggle switch.
Step 9: Programming
<p>//This program is a simple program who will use motor drives (L298N) only to make the motor going straight forward than wait and then backward.<br>//Note that no regu-lation is used and the motor will just go at full speed (in the case of the pipe ro- bot, due to the degrees of freedom of the project this kind of method can be applied.
int mot1plus = 2; //initialisation of the motor pin
int mot1moins= 3;
int mot2plus = 4;
int mot2moins= 5;
int mot3plus = 6;
int mot3moins= 7;
float t_init , t_now , t; //initialisation of the time variables
float t_forward =8;
float t_back = 10;
float t_waiting = 1;
int motorSpeed=0;
void setup()
  Serial.begin(9600);//give the values of the variables if mantioned inn the code (can be delete)
 pinMode(mot1plus,OUTPUT);//initialisation of the pins as output
 pinMode(mot1moins,OUTPUT);
 pinMode(mot2plus,OUTPUT);
 pinMode(mot2moins,OUTPUT);
 pinMode(mot3plus,OUTPUT);
 pinMode(mot3moins,OUTPUT);
  t_init=millis(); //initialisation of the time as variable and start to count
  t_forward *=1000;//transformation of the time in seconds
  t_back*=1000;
  t_waiting *=1000;
</p><p>void loop()<br>{t_now=millis();
t=t_now-t_init;// use to calcul the time in the loop
if (t<=t_forward){ //first loop the robot goes forward
  digitalWrite(mot1moins,LOW);
 digitalWrite(mot1plus,HIGH);
 digitalWrite(mot2moins,LOW);
 digitalWrite(mot2plus,HIGH);
  digitalWrite(mot3moins,LOW);
 digitalWrite(mot3plus,HIGH);
  }</p><p>if (t>t_forward) { if (t<=t_forward+t_wait){
 digitalWrite(mot1plus,LOW);
 digitalWrite(mot2plus,LOW);
 digitalWrite(mot3plus,LOW);}
  }</p><p>if (t_forward+t_waiting<=t){//third loop the robot come back<br>  digitalWrite(mot1moins,HIGH);
 digitalWrite(mot2moins,HIGH);
  digitalWrite(mot3moins,HIGH);
 while(t>=t_forward+t_waiting+t_back){ // the code is block in this loop and the robot stop
}</p><p><br></p><p><br></p><p><br></p><p><br></p><p><br></p><p><br></p>
Step 10: Tests and Results
Finally, it's time to test it.
We tested our robot in different diameters. The first test was in a pipe with a diameter less than 260mm but it was too compressed to be able to move forward, it moved hardly inside this pipe.
However, it performed quite good for other diameters (300mm,320mm). Also, it proved capable of working in larger diameters but as a car (without compression).
This robot is designed to work in horizontal cylindrical pipes or slightly tilted ones. Nevertheless, further improvements are possible for lager inclination angles or for uneven surfaces.
If you like this project don't forget to vote for us in the ''FIRST TIME AUTHOR" contest :)
First Time Author
First Time Author
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    8 Discussions
    AkayeedJ
    AkayeedJ
    1 year ago
    I would very glad to you that (Please) if you give me the report or paper of this project.
    Thank You....
    Jean0x7BE
    Jean0x7BE
    Tip 1 year ago
    Incredible! As a former inspector using professional ROVs based on this concept, you guys have gotten a long way! I can see some challanges with possible climbing up on the side of the pipe, but with enough bottom weight and steering that should be managable.
    A lot of people actually does this kind of inspection for a living, inspecting pipelines and reporting errors. After many years of experience in the field, ruggedness is one of the keywords I would like to point out!
    And you actually were to implement this in some kind of production, I really, really recommend a cord for steering power and transmission of picture. Use a proper cable with shielding in it, so you won't rip apart the leads inside if so.
    Congrats on a great first instructable! Really interesting, and if you develop it further, please give us a shout! :D
    https://www.rico-gmbh.de/10-1-Carriages.html <- This is one of the leading firms in the world creating these kinds of ROVs.
    By the way, if the tought of using belts like on a tank instead, don't try it - been there, failed that - it wouldn't stay in the bottom and required way to much steering control.
    Keep up the nice work, and thanks for sharing it =)
    FatimaB18
    FatimaB18
    Reply 1 year ago
    I like it
    Cdushimy
    Cdushimy
    Reply 1 year ago
    Thank you very much for your feedback and interesting insights!
    hhelium
    hhelium
    Reply 1 year ago
    Thank you very much!!
    devgold
    devgold
    1 year ago
    great idea
    AchrafA17
    AchrafA17
    1 year ago
    Vielen Dank :) :) :) :)
    NayaC
    NayaC
    1 year ago
    such a great idea
