Introduction: Play With Fire Over WIFI! ESP8266 & Neopixels
Create a cool fire simulation effect with Wi-Fi wireless control. A mobile app (for Android smartphones) with a good looking interface is ready to install to play with your creation! We will also use Arduino and ESP8266 to control the flame. At the end of this project you will learn:
- How NeoPixels work.
- How to program ESP8266 and control variables over wifi
- How to create a cool fire effect with Neopixels
Step 1: An Introduction to Neopixels
Individually addressable LEDs or often called Neopixles have been around for quite some time now and you probably know them but, if you don’t, they are like normal RGB LED’s but as the name suggests the color of each one of them can be addressed individually, allowing infinitely cool patterns and animations to be made. For WS2812b you only need 3 wires, 2 for power and 1 for data. That means you just need one free Arduino pin to control a ton of LEDs!
In this project, we are going to use these smart LEDs to create a fire effect. For controlling LED’s we are going to use the awesome FastLED library. We will use the Fire2012 sketch example of the library written by Mark Kriegsman. We use 6 strips of LEDs each having 30 LEDs (a total of 180 LEDs) we stick this LEDs on a piece of PVC pipe and place them in a glass cylinder (these glass cylinders are usually used as vases). We have to diffuse the light of the LEDs to make them look continuous, to do that we used tracing paper which lets light through and diffuses light.
Step 2: Required Materials
Hardware Components
- ESP8266 Serial WIFI Witty Cloud Board×1
- Neopixels Smart LED Strip (60LED/m strip)×1
- Logic Level Converter ×1
- 21cm 40P Male To Female Jumper Wire ×1
- PVC pipe 60cm size 2” ×1
- Tracing paper ×1
- Glass cylinder ×1
Software Apps
- Arduino IDE
Hand Tools
- Hot glue gun
- Soldering iron
Step 3: Construction
First off get a proper glass cylinder, our cylinder has a length of 60cm and a diameter of 12cm.
If you can find frosted glass cylinder that will be nice but if it’s a clear glass you can use tracing paper to cover the cylinder surface (either inner or outer surface), tracing paper does a good job of diffusing the light and yields good results. After getting a glass cylinder measure its internal length and then cut the PVC pipe so that it fits inside the cylinder. Our glass cylinder has a height of 60cm (excluding base it has an internal length of 59cm) so we cut our PVC pipe to 59cm. You will stick LED strips on this pipe, a pipe with diameter of 4cm would be perfect. Next we have to cut our led strip to 6 equal parts here we use 60LEDs/m density strip (you can use higher densities for better effects if you want to) we use six 50cm lengths, that means we need 3 meters. Space the six lengths equally around the PVC pipe and stick the strips to the pipe. Here’s how it should look like.
To the LED strips together you can either directly solder wires to the strip according to the following drawing or first solder pin headers to the strips and then use breadboard wires to connect them.
When all LED strip connections are done you have to place the pipe inside the cylinder. To Center the pipe inside the cylinder you can use foam to cut a circle which has an outer diameter equal to the inside diameter of the glass cylinder and an inner diameter equal to the outer diameter of the PVC pipe. Prepare two of these for each side of the pipe. Attach these parts to the ends and gently put the pipe inside the cylinder.
Step 4: Code
We use Arduino IDE for coding and uploading to ESP8266. You have to use a board which has an ESP8266 with 3MB of SPIFFS if you want to upload the controller software files on the SPIFFS. SPIFFS is short for “Serial Peripheral Interface Flash File System” you can upload the controller files to this memory to serve the files from that location. By doing this you can open your browser (either on your phone or notebook) and go the address of your ESP (the default is 192.168.4.1) and you will get the controller interface in your browser without having to install the app, if you have an iPhone or iPad this is your only choice.
Upload the following sketch onto your ESP board. We need FastLED library, so first add it to your Arduino IDE if you haven’t already (You can download it here). The fire simulation code is Mark Kriegsman’s fire2012 sketch which you can find in the examples. That example is for one strip of led but, here we have modified the code to use a variable number of strips. The more the number of strips/leds the greater the effect will be. The logic of the fire simulation is clearly described in the example file. If you want to know how it works read the source code of the example.
Step 5: App
To control the “look and feel” of the fire there are two variables to play with: SPARKING and COOLING, which you can dynamically control in the controller software uploaded to the SPIFFS or the android app you can download. You can also control FPS here.
The color of the fire is controlled with a color palette which is also changeable through the controller software (through 4 color stops). Just click/tap each color circle representing a color stop to set the color, after setting the color hit close to close the dialog and see the change.
Step 6: How to Upload to SPIFFS?
To upload the files to the SPIFFS memory using Arduino IDE first you need to create a folder called “data” inside the sketch’s folder and place all the files you want to be uploaded in that folder. The file uploaded here contains both the sketch and this folder.
Next, you need Arduino ESP8266 filesystem uploader plugin for Arduino. Follow the instructions on its Github page and install the plugin. When installed you will find ESP8266 Sketch Data Upload under tools menu. Put your ESP into programming mode and click that. Be patient and let the files upload, that might take a little while. Note: set “upload speed” to 921600 to make it faster.
Step 7: How Does It Work?
The sketch uploaded onto the ESP8266 board creates a web server on that, which responds to the requests sent from the app. The app simply sends GET requests to the server (ESP8266). The data of color to create the palette are sent as arguments in the get request, the same is true for other parameters such as Sparking and Cooling parameters.
For example, to set the brightness, the following request is sent by the app http://192.168.4.1/conf?brightness=224 there is a handler for this request in the sketch that when gets this request sets the brightness. Review the code to find out more.
Step 8: Android App
Android app is created using Phonegap. It is a technology that allows you to create cross-platform mobile apps using web technologies (HTML, CSS, Javascript). You can get the source code from the following link.
![Color Recognition W/ TCS230 Sensor and Arduino [Calibration Code Included]](https://content.instructables.com/F9K/6MIC/K7BBJPVB/F9K6MICK7BBJPVB.gif?auto=webp&crop=1%3A1&frame=1&width=130)
