Pocket Soldering Kit
Introduction: Pocket Soldering Kit
About: With 21 Featured Instructables, and Over 1 Million Views, I think I am doing pretty good here, with my wacky ideas!
I have a big back garden, and the perimeter of the garden is all low voltage lighting, and with sun and weather and the occasional chicken pecking at the wire, I am out there once a month fixing a broken wire.
Lugging out a soldering iron and a 100' extension cord all the time to fix it, was a pain, so I came up with a pocket soldering kit.
Teacher Notes
Step 1: Intel Inside
Amazing how much stuff you can put into a small tin.
Torch Lighter (Amazon link)
Alligator clip and extension (to hold wire while soldering)
Solder (60/40 rosin core)
Heat shrink tubes (assorted)
and a small tube of clear silicon (won't fit in tin)
I have a pair of wire strippers, I cut out broken wire, strip new wire, slip on a piece of heat shrink, solder wire with torch, let it cool a moment, squirt some silicon into the heat shrink tube (to waterproof it) use torch to shrink tubing, test and DONE!
Pocket Sized Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • First Time Author Contest
    • Silly Hats Speed Challenge
