Popsicle Stick Robotic Arm
3,428
30
8
Here's how to build a simple robotic arm with a gripper using popsicle sticks, an Arduino, and a few servos.
Supplies:
Feel free to use similar materials or whatever you already have. (e.g. cardboard instead of popsicle sticks)
Materials:
  • 14 Popsicle Sticks
  • 4 Micro Servos (with their horns and screws)
  • 4 Rotary Potentiometers
  • 1 Half Size Breadboard
  • 1 Arduino Uno
  • 1 6-Volt Battery Pack
  • 26 Jumper Cables
Tools:
  • Hot Glue Gun + Hot Glue Sticks
  • Precision screwdriver or other small screwdriver
  • Arduino IDE
  • USB to Arduino Cable
Teacher Notes
Step 1: Choose Horns for Your Servos
Materials for This Step:
  • 4 Micro Servos
  • 3 Horns that extend in 2 directions
  • 1 Horn that extends in 1 direction
Instructions:
Attach the horns (white wing attachments) to the servos. Three of the servos need the horn that extends in two directions while one servo will need the horn that extends in just one direction. Simply pop the horns onto the top of the servos.
Step 2: Calibrate the Servos
  • 4 Micro Servos
Instructions:
Turn the horn counter-clockwise as far as possible. Then, pop the horn off and back on at the calibrated position.
One of the servos with the double-direction horns needs to be calibrated parallel to the servo while the other three need to be calibrated perpendicular to the servos.
Above is a picture of the calibrated servos turned fully counterclockwise. These are the calibrated positions.
Why calibrate the servos? Servos only move 180 degrees so it's important that we calibrate the servos so that the servo turns between the angles we want therm to.
Step 3: Screw in the Servos
  • 4 Micro Servos
  • 4 Small Screws
Instructions:
Screw the horns in using a small screw and the appropriate screwdriver.
Step 4: Attach Popsicle Sticks to Servos (pt 1/4)
  • The one servo that was calibrated so the horn is parallel to the servo
  • 1 Popsicle Stick
  • Hot Glue Gun
Instructions:
For the servo that was calibrated so the horn is parallel to the servo, hot glue one end of the popsicle stick to the flat side of the horn.
Above is a picture of this servo turned completely counterclockwise.
Step 5: Attach Popsicle Sticks to Servos (pt 2/4)
  • One of the other two servos that have double-direction horns
  • 1 Popsicle Stick
  • Hot Glue Gun
Instructions:
Glue one end of the popsicle stick to the flat side of the servo's horn.
Step 6: Attach Popsicle Sticks to Servos (pt 3/4)
  • The last servo that has a double-direction horn
  • 1 Popsicle Stick
  • Hot Glue Gun
Instructions:
For the other servo, glue the middle of the popsicle stick to the flat side of the horn.
Step 7: Attach Popsicle Sticks to Servos (pt 4/4)
This step is different. Read carefully!
  • The one servo with the single-direction horn
  • 1 Popsicle Stick
  • Hot Glue Gun
Instructions:
Glue one end of a popsicle stick to the thin clockwise side of the horn. Yes, the popsicle stick is "sideways" compared to the previous step. This may be a little tricky to glue.
Step 8: Create a Base for One Servo
  • The single servo that's calibrated so the horn is parallel to the servo
  • 4 Popsicle sticks
  • Hot Glue Gun
Instructions:
Hot glue four popsicle sticks so that they're stacked on top of each other. Tear off any excess glue on the edges.
Then, glue the bottom of the servo to the center of the continuous flat side of the popsicle stick stack. Tear off any excess glue.
Step 9: Build the Base for the Whole Robot!
  • 6 Popsicle Sticks
  • Hot Glue Gun
Instructions:
Lay 3 popsicle sticks down in one direction. Then lay 3 popsicle sticks in the other perpendicular using hot glue to connect everything.
Step 10: Connect the First Servo
  • The single servo with the middle of the popsicle stick glued onto the servo
  • Hot Glue Gun
  • The Base for The Whole Robot from the last step
Instructions:
Glue the bottom of the servo onto the base.
Step 11: Attach the Second Servo
  • The servo with the stack of popsicle sticks attached to the base
  • The structure from the last step
  • Hot Glue Gun
Instructions:
Orient the servo sideways so that the popsicle stick can rotate upwards in the air.
Glue the bottom facing edge of the popsicle stick stack to the existing structure. (see picture)
Step 12: Attach the Third Servo
  • The last servo with the double direction horn
  • Hot Glue Gun
Instructions:
Glue the servo to the end of the existing structure's protruding popsicle stick so that the servo's popsicle stick rotates away from the center of the robot
Step 13: Attach the Last Servo! (Gripper)
  • The last servo
  • Hot Glue Gun
Instructions:
Glue the large flat side (as opposed to the bottom of the servo used in previous steps) to the close side of the last servo's popsicle stick so that this servo's popsicle stick rotates in the same area as the last servo's popsicle stick.
When gluing, make sure to angle the servo so that when the servo is rotated about halfway, the two popsicle sticks touch at the very tip.
Above is a picture of an open and closed gripper.
Step 14: Assemble the Circuit!
  • 1 Half size breadboard
  • 1 Arduino Uno or equivalent microcontroller
  • 26 Jumper cables
  • 1 6-Volt battery pack (6 volts max)
Instructions:
Replicate the diagram given above!
Step 15: Upload the Code!
  • Arduino IDE
Instructions:
Upload the following code to your arduino using the USB cable:
#include <Servo.h>
Servo servo1; // Servos
Servo servo2;
Servo servo3;
Servo servo4;
const int pot1 = A0; // Attach potentimeters
const int pot2 = A1;
const int pot3 = A2;
const int pot4 = A3;
void setup() {
  // Set up everything and will run once
  servo1.attach(6); // Attach servos and define the pin modes
  servo2.attach(9);
  servo3.attach(10);
  servo4.attach(11);
  Serial.begin(9600); // Begin the arduino/loop
void loop() {
  // put your main code here, to run repeatedly:
  int pot1Value = analogRead(pot1); // Read the values of the potentiometers
  int pot2Value = analogRead(pot2);
  int pot3Value = analogRead(pot3);
  int pot4Value = analogRead(pot4);
  int pot1Angle = map(pot1Value, 0, 1023, 0, 179); // Map the values of potentiometers (0-1023) to angles that the servo can read (0-179 degrees)
  int pot2Angle = map(pot2Value, 0, 1023, 0, 179);
  int pot3Angle = map(pot3Value, 0, 1023, 0, 179);
  int pot4Angle = map(pot4Value, 0, 1023, 0, 179);
  servo1.write(pot1Angle); // Make the servos move to the mapped angles
  servo2.write(pot2Angle);
  servo3.write(pot3Angle);
  servo4.write(pot4Angle);
Step 16: We're Done!
Turn the potentiometers to control the robot!
Step 17: Troubleshooting
It isn't moving!
Make sure the battery pack is on and the Arduino is plugged in.
Double check the circuit to make sure everything is correct and plugged in.
A servo isn't working
First, try hitting the reset button on your Arduino. Sometimes a servo might stop working if we push it too far.
The servo may simply be dead, try plugging the circuitry for that servo into another servo and see if the new servo works.
If it doesn't, the problem lies within your circuitry.
Servos are jittery!
Your servo simply may be jittery.
The servo may be bearing too much weight.
Try adding a capacitor to the power wiring for the servos.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    8 Discussions
    randofo
    7 weeks ago
    I like how simple this is to build and get running!
    Hailiaxrashaeavery
    Answer 6 weeks ago
    I used 10K but I don't think it really matters.
    Melonduofromage
    8 weeks ago
    Seems like it's suffering from parkinson : ). Good job though, you won't get a precise movement with those cheap servos anyway. My idea is mounting servos on the hull and using strings for control movement, like tendons in your hand, that might reduce weight on the arm and would allow smother move. In theory. I have never tried it. I know it's a simple project, and you used no complicated parts, made it out of sticks, which is pretty remarkable, still made good job explaing it.
    HailiaxMelonduofromage
    Reply 8 weeks ago
    Hahah yeah, could have used stronger servos. Interesting idea, thank you!
