Portable Solar Lighting System or Battery Charger
2,932
31
4
Introduction: Portable Solar Lighting System or Battery Charger
About: I like to build some cool stuf
I first made this sollar light last summer when we had problems with electricity in our cabin (tree fall on the power line and we didn't have any light source when we wanted to stay there overnight)
it works very well and when my friend saw it he asks me if I can make him something similar for camping
so I decided to make PCB because it has problems with overheating and soldering components together just with wires was a too long process
it is made out of three LiIon battery chargers for three 18650 batteries (you can use any Li-ion battery)
each battery have its own charger with protection circuits and if solderable jumpers are not soldered you can use each battery separately
when you connect one of these jumpers they will connect battery to battery out terminal and to the step-up converter if you add switch or jumper to switch terminal
out terminals from step-up converter are marked as 5V out because I using USB lights from eBay
but you can also use it for whatever you want just set different voltage
Teacher Notes
Step 1: Components and Tools Needed
main components for PCB:
1. PCB ready to order link to PCBway just click and order 10 boards only for $5
if you are a new customer you can get 5$ discount link just register and get your discount
or download my gerber files
2. charger module ebay link (one with three chips as on my photo)
3. step-up converter with XL6009 chip ebay link buy same as on my picture I had a very similar one but the chip was fake, it doesn't work very well and it also didn't fit on my PCB
4. thermal pad or compound for charger modules is better compound, step up has pins on the bottom from trimmer so you need to cut them and thermal pad could help to isolate it from touching the ground on PCB
5. battery holders and batteries
holders must be separated, one for three batteries doesn't fit
other componnents:
1. enclosure box
2. connectors male, female
3. wires
4. switch
5. lights link I used colorful ones which were marked as 5 and 7W
but 7W was actually around 5W
6. solar panel 20W or more (if is above 6V you need step down converter)
tools:
1. soldering iron and solder wire
2. plyers
3. drimmel (optional)
4. drill press or drill
Step 2: PCB Assembly
1. cut piece of cooling (heat conductive) pad or add thermal compound under charging circuit
and solder it to PCB board using some wire in holes for better strength and conductivity
when you using thermal pad apply a little bit of pressure when you soldering first two contacts for better thermal conductivity
2. step up converter has pins from the bottom site which could cause a short circuit when they scratch through soldermask so is better to cut or sand them as flat as it possible if you using thermal compound add a piece of plastic or electrical tape under cutted pins for better isolation
and solder it to the board using wires as in the first step
3. battery holders are not necessary you can use different types of LiIon battery than 18650
but if you decided to use 18650 batteries you can solder three holders on the backside of PCB or more batteries connected parallel to each charger but keep in mind one charger is set to 1A of charging current so charging will take longer
4. measure everything for possible short circuit and if is everything OK add a blob of solder to solderable joints under each charging circuit if you don't want to use one or more batteries separately
you can also add some extra components as you can see on the last photo
Step 3: Preparing and Wiring Enclosure Box
I used ordinary wall junction box, originally I wanted my box to be waterproof but one which used had bad design and water was leaking through screw holes other which I bought for the first prototype was better but after few months outside plastics start decomposing and it had a very weird smell and rough finish so it is no longer good as a portable box (it is just on surface it is common with these boxes it will last few years) this new box which I used in this instructable is made from different plastic so I will see if it will decompose same way or not
but now back to work:
if you have all components you can decide exactly where you want them always is better to make some sketches and template on paper
then you can punch holes with marking pin and start drilling first with smaller than with larger drill
when you using additional components use a small file to finish holes for needed dimensions
if you have all necessary holes you can put all components in and start wiring
when you have everything wired check correct polarity and connections with a multimeter
if is everything ok add batteries and test if it works
Step 4: There Are Many Ways How to Connect It Here Is Simple Version
click for more images they contain little notes
Step 5: Usage
you can use it for cabin gazebo.... for that you can use classic glass solar panels
if you plan to use it as a portable light source for camping, fishing..... is better to use flexible solar panels
when your solar panel have more than 6.6V you should use step down converter set for 5V close to charging connector
for example 12V 20W panel should be enough
if you don't plan to use it for some time you should discharge batteries to 3.7V to prevent capacity loses
and remove them from holders if is possible
Step 6: I Wish You Best Luck If You Decide to Make It
feel free to ask any questions
when you make it you can send me a photo :)
PCB Contest
PCB Contest
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
    4 Discussions
    GoArif
    GoArif
    1 year ago
    Nice Project Bro!
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    thanks
    RikW8
    RikW8
    Question 1 year ago on Step 6
    A friend of mine was talking about putting some accent Lighting in this house using solar power. Your setup seems perfect. I kind of breezed through it and forward it to him. But my question is do you have a cost on this equipment.
    nikdo_nic
    nikdo_nic
    Answer 1 year ago
    10 boards from PCBway or JLCPCB cost under $10 including shipping
    and other components are pretty cheap
    charging modules 10pcs around $4 (you need three)
    step up around $1
    I used 3x Panasonic NCR18650B they cost around $3.50
    their capacity is 3400mAh
    box $1.50
    connectors 10pcs around $2
    so whole basics box is around $15
    + lights ($2/piece)
    and solar panels 20W around $30
    I bought 10pcs 6W flexible panels for $85 (they cost $5.5 each but shipping was expensive)
    you can find links to most of the components in my instructable
