3D Printing Portuguese Azulejo Tiles
10,016
93
25
Introduction: 3D Printing Portuguese Azulejo Tiles
About: I am a Software Engineer who likes to tinker with many different technologies. One motto I try to live by is " I can stop learning when I die".
My wife and saw Azulejo tiles when we did a trip to Portugal. The tiles were great and we are very interested in integrating some into some house projects, but there are two issues when attempting to source materials, finding design(s) that we both liked and/or had to purchase in quantities well beyond what we needed. So to remedy this, I found some test designs online and began tinkering to see what I could build with my Prusa i3 Mk3.
Step 1: Finding a Design You Like
So to start off I found some photos online (non-commercial) and downloaded them. From there I used Gimp to clean them up and created a silhouette of each color, with the exception to the white. For the first two tiles, this was just a single jpg I created and then for the second (tricolor) file I created two jpg images. These files are simple black and white, just to create a vector file from. I used the website https://convertio.co/jpg-svg/ to convert the jpeg files to a vector file (svg).
Step 2: Make Your 2D Image 3D
Now that you a vector file, let's make it 3D. I went simple and used Tinkercad, import the file and then give it some depth. I made the design 1 mm thick and then i made a square base for the entire tile that was also 1mm thick with a wall around the perimeter, to catch the white drywall spackle filler I will use later.
I attached the stl files here so you can see what I built.
Step 3: PRINTING (my Favorite Part!)
This part is pretty simple now that I know how to print relatively well. I would suggest using PLA vs something like ABS because I've found that ABS warps too much especially as you get a larger print area for thing pieces such as this (if anyone has suggestions for fixing this i'm all ears). You can go up to very thick layers for this print, doesn't need to be nice and fine. I ran these at 0.2 mm per layer which was the highest Slic3r allowed me to go. As you can see I do not have a multi-material printer so for the tri-color tile I printed the orange separately.
For the orange I did have to use an xacto blade to shave off some of the edges to get it to fix, but it was overall very minimal.
Step 4: Spackle Up Your Tile
So I used some simple and inexpensive FIXALL brand drywall spackle for this. It is pre-mixed and I bought white vs the tan color that is also available. Using a putty knife I scooped up a good helping and lathered it on a nice thick layer across the entire print. I looked to fill in any holes or gaps then I gently as one would with a normal drywall fill, scraped off the excess trying to have a nice level surface across the entire tile. Don't worry about the printed are being very visible, we'll take care of that later. As you can see with the last few photos the image looks a bit ghost like through the spackle, which is perfect. Let this sit for several hours (I usually let it dry overnight just to to be saved, some of the larger depressions take a while to dry and you want this to be hard and rigid). You can poke one of the bigger white areas and if it is like putty or just soft and not hard, then it's not dry enough yet for more.
Step 5: Sanding Away the Extra Spackle and Filament
So I first tried to do this with a hand sander, which works well except on large open areas such as with the bird tile (mind you the bird tile is about 10"x10"). The orbital overall had more success with not pulling up too much of the spackle and getting everything smooth and level. I still used the hand sander on a few areas. This is needed to not only remove the extra spackle but to give the filament a smoother finish. Because I didn't use the Cura software to make my gcode file for printing I did not have the ironing feature (I plan on trying that in the future) so to compensate for having the "lines" from laying down the filament I did a little extra sanding to make it smoother. It's starting to look like a tile at this point. I then just to clean everything off took some isopropyl alcohol on a paper cloth and gently wiped off the entire surface.
Step 6: Make It Shinny
Now I have only done this to the two smaller tiles, the larger one I plan on using food safe pour on resin to see if I can make it into a cutting board. I used some rustoleum semi-gloss clear spray paint. I know the spray paint in the photo says satin, which is what I tried first, but I did a second semi-gloss coat after I realized how poor the shine was one it. I did one coat, let it dry for about an hour or so then sprayed on a second coat. After several hours outside getting the lovely smell to dissipate it was ready and I must say looks pretty great!
So we plan on finding some designs (or making some custom designs) and using them for some accent shelving backslashes in the kitchen.
I am always open to comments, suggestions and even criticisms of my work. What did you think of this?
Faux-Real Contest
First Prize in the
Faux-Real Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    25 Discussions
    Matlek
    Matlek
    1 year ago
    Very creative, it looks great!
    wentworthm
    wentworthm
    Reply 1 year ago
    Thank you!
    CraftAndu
    CraftAndu
    1 year ago
    Looks great!
    wentworthm
    wentworthm
    Reply 1 year ago
    Thanks!
    wentworthm
    wentworthm
    Reply 1 year ago
    Ive seen this just haven't tried it yet. Thanks for the link!
    ChiefInstructor
    ChiefInstructor
    1 year ago
    What a great and creative idea. Well done. Would like to see pics of the tiles in action when you get the chance.
    wentworthm
    wentworthm
    Reply 1 year ago
    I promise a future instructable for that
    ERisi
    ERisi
    1 year ago
    How will the tiles be used? I don't think they are durable enough to walk on. Will they be used as a backsplash in the kitchen?
    wentworthm
    wentworthm
    Reply 1 year ago
    I am making some custom accent shelves for our kitchen and these will be the backslashes. You’re right they’re not strong enough for flooring unless I did a layer of pour on resin over them.
    asadabdul
    asadabdul
    1 year ago
    Great job! Maybe you could use Inkscape software to create your svg files from jpeg or drawing them there from scratch instead of use an online convertion service.
    wentworthm
    wentworthm
    Reply 1 year ago
    Thanks i'll give that a look!
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    I'm super impressed how these 3D printed tiles turned out! They just look great!
    wentworthm
    wentworthm
    Reply 1 year ago
    Thank you!
    edebrigard
    edebrigard
    1 year ago
    I am fascinated by your process. I would like to see photo of the tile or tiles in use, because the proof of the pudding is in the eating, isn't it? What makes the azulejos so attractive in Portugal is the way they completely sheathe the fronts of buildings, the way they make a courtyard seem large and cool, the way they make you think of the past -- your tile is a tour-de-force that makes me admire your skill, but it does not do any of these other things. The main purpose of tiles is to protect a building surface -- do you have surfaces that you need to treat this way? You say you were planning to use azulejos in the kitchen -- I would really like to see how they turn out. Another place where they might be useful is to cover the walls of the children's room.
    edebrigard
    edebrigard
    Reply 1 year ago
    I am not saying that the ceramic azulejos are better. I am intrigued by your process and by the end product. In both situations, it is how it works that is important. In Portugal, the purpose was to protect surfaces. In your translation, the purpose is to embellish the house with some happy memories. I think in those terms it is an unqualified success! Also, let’s think about the “azul” in azulejo — blueness is a big part of the appeal of the tiles. You have captured a very intense blue.
    wentworthm
    wentworthm
    Reply 1 year ago
    Thanks!
    wentworthm
    wentworthm
    Reply 1 year ago
    I'll post some of the final product. They most likely won't be as grand as you very correctly stated they are meant for. But we wanted them for some very specific accent shelves. I agree with your statement of their utility and admit my project does create a 1 to 1 facsimile, but it is not meant to. My intention is not to compete with the very impressive artists that create the real thing, but to do something which honors them using a newer technology. These "replacements" cannot compete the fact that real Azulejo tiles are always better. This is just cheaper and you can make what you want.
    diogommr
    diogommr
    1 year ago
    As a Portuguese and Portuguese Tile lover myself, I congratulate you on your awesome project idea. Keep up the great work!
    wentworthm
    wentworthm
    Reply 1 year ago
    Thanks!
