Introduction: Power Arduino With a 1.5V Battery
In this tutorial we will use a step UP (0,9-5V to 5V) Voltage Booster to Power Arduino UNO with a 1.5V Battery.
Step 1: Check Out My Other Tutorials
Click here to Check Out My Other Tutorials
Step 2: What You Will Need
- Arduino UNO (or any other Arduino)
- Step UP (0,9-5V v 5V) Booster
- Battery Holder for the 1.5v Battery
- 1.5V Battery
Step 3: The Circuit
Connect Battery Holder Positive pin to Step Up Booster pin Vi
Connect Battery Holder Negative pin to Step Up Booster pin GND
Connect Battery Holder Negative pin to Arduino pin GND
Connect Step Up Booster pin VO to Arduino pin [VIN]
Note: Some modules have reverse pins so make sure that you connect V0
Step 4: VISUINO Special Edition
All you need to do is drag and drop components and Connect them together. Visuino will create the working code for you so you don’t have to waste time on creating the code. It will do all the hard work for you fast and easy! Visuino is perfect for all kind of projects, you can easily build complex projects in no time!
Download the Latest Powerful Visuino Software
