Introduction: Project 7 : Ultrasonic Model HC-SR04
Ever wanted to know the empty distance between any two points. Use the Ultrasonic HC-SR04 with the Arduino Board. So let's get started !!!
Step 1: Step 1: What You Require?
- Arduino Uno or Arduino Mega 2560 (They are the beginning boards of Arduino)
- Jumper Wires (Male to Male)
- Breadboard
- HC SR04
- Cable (To connect board with your Computer for uploading the Program)
- Arduino IDE Program (Downloadable fromhttps://www.arduino.cc/en/Main/Software
Step 2: Step 2: Build Your Circuit and Know Why Is It Designed So?
GND on the Ultrasonic Module is to be powered by negative energy. You can use external power source also but I have used GND power from the Arduino Board itself.
Trig and Echo need to be connected to Analog Input Pins. An analog input converts a voltage level into a digital value that can be stored and processed in a computer.
VCC on the Ultrasonic Module is to be powered by positive energy. You can use external power source also but I have used 5V power from the Arduino Board itself.
Step 3: Step 3: Now for the Software
#include <NewPing.h>
#define TRIGGER_PIN 12
#define ECHO_PIN 11
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
void setup()
{ Serial.begin(115200); }
void loop()
{ delay(50);
Serial.print("Ping: ");
Serial.print(sonar.ping_cm());
Serial.println("cm"); }
You will need the NewPing Library, you can Download it Here : https://bitbucket.org/teckel12/arduino-new-ping/downloads/
