Quick Felt Flowers
452
10
5
Introduction: Quick Felt Flowers
About: Vegan, baker, cosplayer, party planner, traveler, self-proclaimed food monster...
No matter how easy felt flowers are to make, they’re definitely not streamlined or simple! So I came up with a relatively quick way to create wisteria-esque flowers. And if you have a few friends to help, it can certainly be created in just a couple of hours!
Supplies:
  • felt
  • scissors
  • pen or marker
  • glue gun
  • glue sticks
Teacher Notes
Step 1: Fold and Draw
Fold the felt so there are four layers. Then freehand or trace circles onto the felt. They don’t need to be perfect.
Step 2: Cut
Cut the fabric just above and below the circle so that you have a long strip of 4 unattached layers. Then cut between each circle so you have a bunch of squares. Then cut each group of squares (consisting of four layers) into their circle shape. You can also just cut the circles directly but I find this prevents the layers from getting messed up and makes things easier.
Step 3: Glue
Fold one circle over and add a small line of hot glue.
Step 4: Seal
Fold the opposite side over and carefully press to seal, creating a cone shape. The glue can squeeze through the felt so be careful not to burn yourself.
Step 5: Stack
Attach felt pieces together by adding a line of hot glue to the inside edge of the cone. Then just place one cone inside of the cone with the glue and press to seal.
Step 6: Make It Your Own!
The rest is up to you! Use whatever colors and sizes that you would like. I would suggest at least 3 different sizes from large to small depending on the length you're going for. I used string to hang mine from a circular ring to create a chandelier but you could also tie them to balloons or glue directly to a backdrop.
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    5 Discussions
    FineSilver99
    FineSilver99
    2 months ago
    Thank-you for posting an easy way to make felt flowers!!
    Gadisha
    Gadisha
    2 months ago
    Looks good, thanks for sharing your technique :)
    seamster
    seamster
    2 months ago
    Nice! Great technique and excellent results. Thank you for sharing! : )
    SomethingSoSam
    SomethingSoSam
    Reply 2 months ago
    Thanks so much!!
