RF Transmitter and Receiver
39,172
281
48
About: Student of Mechatronics
In this project, I will use RF modules with Pic 16f628a. It will be a short tutorial about rf. After you learn ho rf modules communicate with each other you can use these modules with pic microcontroller, ardunio or any microcontroller. I controlled RGB LEDs but If you can control many thing motors or relays.
Step 1: Short RF Lesson
What is RF?
In short term, radio frequency (RF) refers to the rate of oscillation of electromagnetic radio waves in the range of 3 kHz to 300 GHz, as well as the alternating currents carrying the radio signals.
How does it work?
We need two modules which are transmitter and receiver. Our control our data 1 and 0(we use the microcontroller in this project) and transmitter send these data in Seri way in radio waves. After ıt started broadcasting, receiver collect these radio waves and it gives as 1 and 0 again.
Why do we use it?
If we want to communicate some devices without any wire we RF modules is one of the ways.
Step 2: Circuit Schemas
In the first circuit is the transmitter second is receiver.I controlled 3 RGB led by this modules.
Step 3: Component List
Transmitter Part:
  1. pic16f628a
  2. 18pin dip socket
  3. 1n4001 diode
  4. lm7805
  5. 220 uf 16v electrolytic cap
  6. 1 uf cap
  7. 330ohm ^1
  8. 4.7k ohm ^1
  9. Rf transmitter (433 MHZ)
  10. 10k ohm ^4
  11. 4 push button
  12. 5mm led
  13. male header
Receiver Part:
First eight is the same
9.RF receiver (433 MHZ)
10. 5mm RGB led ^3
11.led
12male header
Note:RF modules must be same frequency.
Rf modules link of rf modules
Step 4: Printed Circuit Board
I love using PCB instead of prototype PCB(including many holes), In my opinion, this way is more healthy for circuits. After designing the circuits I printed on the boards but there are some tiny nets so I needed to fix some nets. After fixing operations they go to in acid. Then they are ready for next step.
Step 5: Solder Mask !
Its optional part.
Solder mark has some difficulties but otherwise, it has some benefits.Your PCB can be healthy very long time and short circuit risks become increases.You can find many resources about how can you make solder mask at home.After the solder mask operations, PCB's go drilling operations.
Step 6: Soldering
At last, we soldering the components on PCB. My advice you should solder dip socket first but attach the pics and rf modules after soldering. You should be very careful about short circuits. Besides, rf modules can be effected static electric very easily.
Step 7: Codding
I used PIC CCS for programming. If you have any question about anything just ask it, please.
First, we choose the baudrate you should look that for rf modules datasheet then we define transmitter an receiver pins. Parity is about our data is odd or even but we don't use it in this project, at last, we choose 1 our stop bit.
Preamble Function:
If we try to use the same many RF modules in the same area it will be some provision. We prevent this problem with preamble function. We define an identification for our modules and sent it receiver module.
We can see this function on the oscilloscope.First two pic belong transmitter and second modules belong receiver circuit
Step 8: RUN!
In this project main idea was RF communication thus I did not use qualification pic or oscillator. If you want to obtain better communication you should use high-frequency crystal oscillator and high-frequency RF modules. You should use an antenna.
    • Barbeque Challenge
      Barbeque Challenge
    • Planter Challenge
      Planter Challenge
    • Sensors Contest
      Sensors Contest
    48 Discussions
    sml.bustos
    Question 2 months ago
    Great job, man !
    But... There is not decode section of preamble in the "rf receiver.c"
    NavodJ
    2 months ago on Step 7
    Can you give a clear photo of circit board
    mina_adel_85
    3 months ago
    kindly advice please , can we use the above circuit for controlling DC motors
    MeanFacedP
    6 months ago on Step 2
    Could this be used to repeat a control signal from a RGB LED Strip? I'm trying to think of ways to create synchronized lighting while connected to different power sources. I have been trying to check into Zigbee or Zwave, but i'm not seeing how it could be setup. From everything I have seen with RF it has been setup as a control from one to the other. Though, in simple IR usage now that I think about it the controllers aren't set to independent control and would take the same remote. So multiple IR receivers or blasters would work.
    OEsirikMeanFacedP
    Reply 6 months ago
    I guess yes, it can be use for that
    OEsirikUmer-Ansari
    Answer 6 months ago
    I use brenner8 to upload it you can use that
    christochandy
    10 months ago
    Very poor description. You didn't clearly given the component list (like IC, Resistor, Capacitor specifications)
    onion2
    10 months ago
    What do you think about the oscilloscope used in your pictures ? I hesitate to buy one
    And thank you for your article, it's very useful
    AlphaOmega1onion2
    Reply 10 months ago
    For a scope to keep in your pocket and for the price, they are great. BUT get an original there are many copies that don't work well.
    I was given a kit a few years back. I had a few issues, but the manufacturer was very helpful (and open to suggestions). I don't use it very often, but find it good enough that I don't bother to dust off my Philips CRT scope.
    BTW, a 'scope requires a certain level of skill and knowledge to use and get meaningful results from. But a very powerful tool.
    I also use a USB logic analyser (these are cheap from China) with software that understands many protocols including i2c, making fault finding much easier. Again, a powerful tool that requires understanding to get the most from it.
    OEsirikonion2
    Reply 10 months ago
    Thank you for good comment.It is not so sensitive but It can shows basic difference of signals,thus I like it.
    AlC70
    10 months ago on Step 8
    Be aware that 433 MHz is within the LICENSED UHF amateur radio bands. I license is required to use these frequencies (420 - 450 MHz) at any power level. One of the national hobby shops was recently fined several million dollars for marketing drones that use these frequencies and don't warn consumers about the "non type accepted" products. There are exceptions, just be sure to check with your local authorities before transmitting on these frequencies.
    eburmanAlC70
    Reply 10 months ago
    Seriously? Get of your high horse! These units put out a minuscule signal. It's not enough to even make it outside the walls of my house. What value is there in your comment? You say "check with your local authorities." Which authorities? Are you able to provide so much as one legitimate example of someone who has been prosecuted by the FCC for using one of these units? Citations please.
    JCFLindsayAlC70
    Reply 10 months ago
    I want to play with ham/SW radio reception. Can you recommend a place for beginners to learn, and how to purchase equipment?
    JimG50JCFLindsay
    Reply 10 months ago
    For info and books about Amateur Radio (Ham Radio) see ARRL.ORG. For equipment google ICOM, Yaesu, Kenwood or go on Ebay searching for amateur equipment. Or build your own. 73. JIm
