Introduction: Real World Minecraft
We all Know Minecraft is an awesome game, and Raspberry Pi has made it more awesome. With the Minecraft API we can now write simple python scripts to interface read world sensors and buttons to the Minecraft world.
Step 1: What You Need
1. Bread board ( I am using a tiny breadboard, that is on a dev board ignore all components that are not on the bread board)
2. Switch / Button ( you can use an arcade button for more fun!!)
3. Wires
4. Raspberry Pi
5. 10k or 12 K Resistor
6. 330OHM Resistor
7. LED
Step 2: The Bread Board
Connect the button in a Active Low configuration.
Ignore all components that are not on the bread board :-)
Step 3: Connect Your Pi
Make sure your hook up the VCC to 3.3v and not to the 5v, a wrong connection would damage the Pi.
VCC = PIN1
DATA = PIN 16 (GPIO 23)
GND =GND
Look at step 2 for schematic.
Step 4: Instal Minecraft Pi
I would like to thank Martin O'Hanlon from StuffAboutcode for his awesome tutorial on Minecraft API, which helped me to come up with this tutorial...
You can install the Minecraft on the Pi using the following commands.
NOTE: You should use the latest build of Raspbian to have Minecraft working, if you are using the ada-fruit distro, you would need to update your firmware with the following command
sudo apt-get update && sudo apt-get install raspberrypi* raspi-config
Boot your pi, and login
type startx to go to the desktop
open terminal (icon should be on the desktop)
cd /Desktop
wget https://s3.amazonaws.com/assets.minecraft.net/pi/minecraft-pi-0.1.1.tar.gz
tar -zxvf minecraft-pi-0.1.1.tar.gz
cd mcpi
now run Minecraft....
./minecraft-pi
This automatically installs the API too, you can check out the API in the /api folder under /mcpi.
Step 5: Python Time
Now lets get Python libraries installed... for GPIOs...
Install python-dev and PRi-GPIO...(its better to do this from the default terminal, and not from the desktop)
sudo apt-get update
sudo apt-get install python-dev
sudo apt-get install python-rpi.gpio
Make a folder for your project
cd ~
mkdir minecraftstuff
Copy required libraries to your folder
cp -r ~/mcpi/api/python/mcpi ~/minecraftstuff/minecraft
and start writing your code
OR just clone my repo
git clone https://github.com/sajingeo/minecraftrpi
Step 6: Hello World
Get my code from git hub (helloworld.py)
This would print helloworld on screen, when you press the button
NOTE:when minecraft is running, open another terminal window and run the script
sudo python helloworld.py
Understanding the Code :
import minecraft.minecraft as minecraft
import minecraft.block as block
import time
import RPi.GPIO as GPIO
import os
Import all necessary libraries for the project , RPi.GPIO is used to control the GPIO, and minecraft libraries are used to create blocks and talk to the minecraft world.
GPIO.setmode(GPIO.BCM)
Setup the GPIO driver, enable software control of the GPIOs
GPIO.setup(23,GPIO.IN)
setup GPIO 23 as input. for the button
mc= minecraft.Minecraft.create()
create a Minecraft object
GPIO.input(23)==False
to check if the button is pressed( Active Low)
mc.postToChat("Hello World!!")
print Hello world to Minecraft console
Step 7: Adding a Fire Button
Get my code from git hub (fire.py)
This would create a TORCH(if it is getting dark) block on pressing the button, you can also create blocks like TNT and FIRE .
sudo python fire.py
Step 8: Glowing LEDs
Get my code to glowLEDs here (connect your LED to GPIO 24 -- refer schematic)
Getting the poll function working was a pain, here i am creating a TNT block, and when the player's xPosition Matches with the TNT's x pos, the LED GLOWSSSS.....
Step 9: Adding a Move Button
Get my code from git hub (move.py)
This would move the X-position of your character when your press the button.
NOTE:When minecraft is running, open another terminal window and run the script
sudo python move.py
Step 10: Endless Possibilities
- Buttons to build structures like buildings
- Use pollBlockHits() to glow an LED when you press a button.
- Open you garage door from Minecraft world
- Use Accelerometer to navigate the Minecraft world
- Use Light sensors to control day and night in the Minecraft world
And don't forget to have fun guys...
Game.Life 3 Contest
