Rhinestone and 3D Print Molecule Necklaces
5,834
62
14
Introduction: Rhinestone and 3D Print Molecule Necklaces
About: Community Manager of Instructables - I am powered by rainbow and sugar!
I was looking at some projects on the site the other day and saw a laser cut Serotonin necklace and thought it would be fun to make a 3D printed version that also has rhinestones! I fiddled with the design until It came out just the way I wanted it and this is the results! I thought Serotonin was a good molecule for this project but decided to branch out and so far I have also made Dopamine, Adrenaline, GABA, and Caffeine. I'll talk a little about each molecule in Step 2.
If anyone is interested in the designs with holes instead of inserts for Rhinestones, let me know. It should be a fairly quick and easy process to adapt the design for that.
If you are interested in molecules but not as necklaces, check out these molecule ornaments.
Etsy
I'm also selling these necklaces on Etsy! Check them out :) Serotonin - Dopamine - Adrenaline - GABA - Caffeine
Instructable 290
Step 1: Supplies and Files
For Printing:
For Jewelry Making:
Step 2: Designing the Molecules
I used Tinkercad to design the molecules and it was a very finicky process (not because of Tinkercad but because of the way I wanted the design to look).
I started by designing the parts I needed to make it. This consisted of an oval cylinder and a cylinder with a cone cutout for a rhinestone. I used an oval cylinder for the connector pieces because I didn't want those pieces to just be normal rectangles, I wanted to soften it up a bit and give it some more detail.
In order to get the dimensions about right, I started by bringing in a basic design of the molecule and then scaling it to the length and width I wanted. When I had that, I took my starting pieces and started putting it together. Above you can see how I worked to get the 3 piece intersections and 2 piece intersections to make sure the corners and joins all looked right. Once I finished a design, I constantly exported it and brought it into the slicer to find any errors. Then I went back to Tinkercad and made alterations and repeated the process until I had the final design I wanted.
Since some of the molecules were similar, when I could, I worked with a finished design and altered it to make the new design such as Dopamine and Adrenaline.
I ended up making:
  • Serotonin - well-being and happiness
  • Dopamine - reward-motivated behavior (also sometimes considered the pleasure-seeking molecule)
  • Adrenaline - causing increased heart rate, it is the molecule of energy
  • Caffeine - is a psychoactive drug, known for causing awakeness
  • GABA (gamma-Aminobutyric acid) - reduces excitability / anti-anxiety
Step 3: Print!
I didn't really do anything special for printing except for the 100% infill to make them as sturdy as possible.
Step 4: Gluing
Start by gluing the rhinestones in their spots. Tweezers make it easier to put the rhinestones down on the glue.
Step 5: Assemble the Necklace
Make it however you want, but for mine, I took two pieces of fine chain at about 6.5" long and connected them to the molecule using the 4mm jump rings.
On the other end of the chains, I attached the larger jump ring to one and the clasp to the other.
Step 6: All the Molecules!
Any other molecules you think would make cute pendants? Share your ideas :)
Step 7: Serotonin
Step 8: Dopamine
Step 9: Adrenaline
Step 10: Caffeine
Step 11: GABA
Plastics Contest
Plastics Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Maps Challenge
      Maps Challenge
    14 Discussions
    waynew89
    waynew89
    Question 1 year ago on Introduction
    I don’t know what a sugar molecule would look like, but it would be a way of letting someone know that they are “ sweet. “
    Penolopy Bulnick
    Penolopy Bulnick
    Answer 1 year ago
    It looks like Sugar or Sucrose would be a little too big, but I'm sure it could be done and would look great :)
    Dr H
    Dr H
    1 year ago
    Great idea!
    Are these Rhinestones also available in colors? Then one could use e.g. white ones for oxygen, blue ones for nitrogen, yellow ones for sulfur, green for chlorine and so on. In addition, one may also use copper filament for aromatic and silver for aliphatic parts of the molecules. I guess I will try to construct A, G, C and T in the holiday break.
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 1 year ago
    I think you should be able to find rhinestones in different colors too. I think color coordinating would look really neat :)
    Owl Trained ED Doc
    Owl Trained ED Doc
    1 year ago
    I have very little 3-D printing experience, but with these molecules, there is a isomeric structure (chair - L&D isomers, boat) that is more complicated that the 2-D representations shown here. Is there anyway for the print to come off the plate when printing?
    My 3-D printing experience is limited to the handheld 3-D pen.
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 1 year ago
    You can build up more from the plate, it really just depends on what you want to do. Though, you'll probably need support material if you build up at low angles.
    You can certainly make these more complicated, I was going for more of a basic represenation to give it an easy and clean design :)
    Giulia Art
    Giulia Art
    1 year ago
    These look so stylish :)
    Matlek
    Matlek
    1 year ago
    Beautiful! I really like this 3D printed jewelry series you are publishing (I am thinking about the constellation necklace, the 3D print on tulle fabric, the Halloween jewelry...)! Very creative, I'll probably use these ideas to make some gifts!
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 1 year ago
    Thank you! I'm glad you are enjoying the projects and I hope they help with your making :)
    RayP24
    RayP24
    1 year ago
    Ha ha. Excellent collection. How about a bit of morphine to round off a "Dirty (half) Dozen"
    You could have the necklaces coated in trace solutions of these substances and your skin would absorb them bit by bit!!!!
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 1 year ago
    That would certainly be interesting!
    FOOD by Lyds
    FOOD by Lyds
    1 year ago
    Super creative, once again! I love the caffeine ;-)
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 1 year ago
    Thank you! Yeah, caffeine is fun, I wasn't sure how many rhinestones to add to it, but I'm happy with how it turned out :)
