Introduction: Secure PC Login by PICDEVUSB
This application has very important role in our digital life, because you need a secure PC where you can save your private data. Mostly you login your PC by entering a password, small password has not strength whereas it is difficult to type a long password so now there is no need to enter password for login. You just have to plug your PICDEVUSB to your PC and your PC will automatically login. You can set your password up to 256 characters and it is easy to change your computer’s password in PICDEVUSB. As PICDEVUSB is pocket size so you don’t have any tension about its handling or more over you can make key chain of it to prevent it to loss.
You can get PICDEVUSB from indiegogo link below
we will teach you in detail that how you can customize it, changing its password with complete code.
Step 1: Things You Need
To implement this application of PicDevUSB, you need
1x PicDevUSB
and can get it from the indiegogo link below
Step 2: How to Use
Program your PicDevUSB using the hex file attached below.
After that power up your PC, when your computer needs a password to start then you have to plug in your PicDevUSB to the USB port of your computer and toggle the boot loader switch (shown in figure). It will automatically login your PC. If not re-toggle it and it will work perfectly.
you have to set your computer's password as fed in your PicDevUSB, here the password is "gsi7y".
