Introduction: Seven Segment With Arduino
About: Im a student from Iran. I enjoy life by learning , teaching and creating electronic ,robot and etc related
In this project we will make a seven segment that counts the number from 0 to 9 and every number will be shown for one second and then the next number will be shown and when it reaches 9 it will reset
Things you will need :
  1. common cathode seven segment
  2. wires
  3. bread board
  4. 220 ohm resistor
  5. arduino uno
Step 1: Data Sheet
this project was made using the data sheet shown in the picture
Step 2: Connections
Now connect the parts like shown in picture
we wont be using the H pin on seven segment
connect the common or middle pins together and connect one of them to the resistor and connect the resistor to the ground or GND
connections are like this :
the right side are arduino pins and the left side are seven segments pins
pin a = pin 1 arduino
pin b = pin 2 arduino
pin c = pin 3 arduino
pin d = pin 4 arduino
pin e = pin 5 arduino
pin f = pin 6 arduino
pin g = pin 7 arduino
Step 3: Code
Now copy the code below to your programmer or arduino IDE
Seven segment counter makes your seven segment count from 0 to 9 every 1 second Created by: Mohsen Nasiri visit our site: www.fountainofthoughts.net */
int a = 1; int b = 2; int c = 3; int d = 4; int e = 5; int f = 6; int g = 7; void setup () { pinMode(1,OUTPUT); pinMode(2,OUTPUT); pinMode(3,OUTPUT); pinMode(4,OUTPUT); pinMode(5,OUTPUT); pinMode(6,OUTPUT); pinMode(7,OUTPUT); } void loop () { digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(c,HIGH); digitalWrite(d,HIGH); digitalWrite(f,HIGH); digitalWrite(e,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(f,LOW); digitalWrite(e,LOW); digitalWrite(b,HIGH); digitalWrite(c,HIGH); delay(1000); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(g,HIGH); digitalWrite(e,HIGH); digitalWrite(d,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(g,LOW); digitalWrite(e,LOW); digitalWrite(d,LOW); digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(g,HIGH); digitalWrite(c,HIGH); digitalWrite(d,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(g,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(f,HIGH); digitalWrite(g,HIGH); digitalWrite(b,HIGH); digitalWrite(c,HIGH); delay(1000); digitalWrite(f,LOW); digitalWrite(g,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(a,HIGH); digitalWrite(f,HIGH); digitalWrite(g,HIGH); digitalWrite(c,HIGH); digitalWrite(d,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(a,HIGH); digitalWrite(f,HIGH); digitalWrite(g,HIGH); digitalWrite(c,HIGH); digitalWrite(d,HIGH); digitalWrite(e,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(e,LOW); digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(c,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(c,HIGH); digitalWrite(d,HIGH); digitalWrite(e,HIGH); digitalWrite(f,HIGH); digitalWrite(g,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(e,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); digitalWrite(a,HIGH); digitalWrite(b,HIGH); digitalWrite(c,HIGH); digitalWrite(d,HIGH); digitalWrite(f,HIGH); digitalWrite(g,HIGH); delay(1000); digitalWrite(a,LOW); digitalWrite(b,LOW); digitalWrite(c,LOW); digitalWrite(d,LOW); digitalWrite(f,LOW); digitalWrite(g,LOW); delay(1000); }
