Introduction: Shiratama Eyeball Drinks!
Shiratama is a Japanese snack that translates to 'sweet rice dumpling'. I live in Japan and these are very popular.
They aren't too sweet, so keep that in mind if you give my recipe a try. Your kids might throw them right out the window! They taste almost like Mochi (sticky rice) and some people might consider them bland.
My Shiratama have a subtle sweetness and elastic-bouncy texture. They can be made sweeter with toppings like jam or honey.
Step 1: The Ingredients
These are extremely easy to make!
You only need Shiratama flour, soft tofu and food coloring. Shiratama flour is available on Amazon or at Walmart and Target. It's also called Shiratamako or Shiratama powder. Be careful, because there's a difference between Shiratama flour, Mochi flour and glutinous rice flour. These are similar, but can't substitute each other.
Normal Shiratama is just the Shiratama flour and water, but I use tofu, because it keeps the Shiratama softer much longer. They turn hard quick with water.
My recipe is:
400 grams Shiratama flour
560 grams soft tofu
A smaller batch:
100 grams Shiratama flour
130-140 grams soft tofu
Step 2: Making the Shiratama Mix
You're going to
1. Put the Shiratama flour in a bowl and then place on the soft tofu.
2. Mix with your fingers. No utensils required.
3. Form a ball.
4. Separate pinches of dough to add color to.
Step 3: Adding Food Coloring
You can use powder or liquid food coloring for this.
It's best to roll out the eyeballs, irises and pupils before adding the color so you have an exact count.
After everything is rolled into little balls or 'dango' in Japanese, you can combine them into iris and pupil balls to color.
*Wear gloves when you color the Shiratama. Some food coloring is difficult to wash off.
Step 4: The Eyeballs
These are the eyeballs.
Step 5: The Iris
Once the Shiratama are dyed, you can take off your gloves to make the eyeballs.
1. Flatten out an iris in the palm of your hand using a finger.
2. Place the flat iris on the eyeball.
3. Place the pupil on the iris.
4. Gently press and roll all of the pieces together to make an eyeball.
Step 6: Eyeballs!
Step 7: Cook Your Eyeballs
1. Prepare a large bowl of ice water to put you Shiratama in once cooked.
1. Bring a large pot of water to a boil.
2. Gently drop the Shiratama into the boiling water. All of the Shiratama will sink to the bottom of the pot.
3. When all of the Shiratama are floating, wait 2 minutes.
4. Strain the Shiratama and then transfer them to the ice water.
Once they are firm and not hot, you can freeze them or eat them.
Step 8: Freezing Them
Freeze them in away that they're not touching. This is very important!
Step 9: Use Frozen Shiratama As Ice Cubes!
Step 10: Drinks!
You can use these in mocktails or cocktails!
Kids drink
Add three frozen eyeballs to a wine glass, fill with cider or a clear soft drink and add a few drops of grenadine and one drop of red liquid food coloring.
Adult drink
Do the same as the kids drink, but dump in vodka!
Blueberries compliment these Shiratama well too!
