Introduction: Signal Generator Using Inviot U1, an Arduino Compatible Board
A signal generator project using the
InvIoT U1board
and a module with the IC AD9833 DDS.
The module can generate from 0 to 12.5 MHZ square, triangle and sine wave.
There are many boards with the AD9833 chip. I used the one that has an on board amplifier.
Step 1: Set Up
1. connect the AD9833 module
with the U1.
AD9833 U1
VCC 5V
GND GR
FSY D10
CLK D13
DAT D11
2. Upload the sketch found in the library of the InvIoT. Open your arduino IDE, file/examples/InvIoT_U1/applications/signalGenerator
3. Upload sketch
Step 2: The Code.
I include a file with the code.
The code can be also found in the library, and in order to run the code you need to download the library.
