Introduction:
About: I am here to share what I make. Hopefully, you can learn from watching what I have done and even improve upon it. As an Amazon Associate I earn from qualifying purchases.
Make it Glow Contest 2018
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    4 Discussions
    BrownDogGadgets
    BrownDogGadgets
    1 year ago
    You need a change controller in this mix or you risk overcharging the battery, which could end up causing a fire.
    JanT14
    JanT14
    1 year ago
    Be shure to protect the battery with proper charge/discharge circuitry if you care about safety for both your battery and yourself.
    JemChalweDoPorzygu
    JemChalweDoPorzygu
    Tip 1 year ago
    Try to read about overcharging/discharging protection circuits ;
    tytower
    tytower
    1 year ago
    Once you have learnt and understand that on diodes it is time to learn another property of diodes . All diodes have a zener point . That is a voltage on the diode that is high enough to force current back the other way . IE a diode might have a zener point of 22 Volts . If you put 24 Volts on it then 2 Volts will flow backwards ! The 22 Volts will be stopped.
