Sound Light Robot
About: diyelectronics.webs.com diyelectronics.uphero.com diyelectronics.yolasite.com diyelectronics.weebly.com diyelectronics.narod.ru diyelectronics.angelfire.com twitter.com/diyelectronics facebook.com/diyelectr...
In this Instructable you will be making a sound light device. This device turns on the bright LEDs or light bulbs with music. The music input comes from line out or speak output of a HiFi, computer or mobile phone.
You can see the circuit working in the video.
Supplies:
You will need:
- matrix board,
- heat sink,
- NPN power transistor,
- a few NPN BJT general purpose transistors,
- a two PNP BJT general purpose transistors,
- solder,
- soldering iron,
- encasement (you can use a paper cup),
- electric drill (optional),
- heat transfer paste,
- tape,
- 10 ohm power resistor,
- 270 ohm resistor,
- 4.7 kohm resistor,
- 2 Megohm variable resistor,
- two 1 kohm resistors,
- two 10 kohm resistors,
- 100 kohm resistor,
- 470 nF and 100 nF capacitors,
- nut and bolt for the heat sink,
- a few bright LEDs or two 1.5 V light bulbs,
- scissors or screw driver,
- one general purpose diode.
Teacher Notes
Step 1: Attach the Heat Sink
Drill two holes in the matrix board and attach the heat sink as shown in the photo.
Step 2: Attach the Power Transistor
Attach the PNP power transistor with bolt and heat transfer paste.
Step 3: Build the Circuit
The Rc2 resistor was chosen as 10 kohm instead of 1 kohm to increase the charging time constant. The time constant is a multiplication of capacitor (C2) and resistor (Rb2) value. An alternative would be to use a higher C2 capacitor value but this would mean using a electrolytic capacitor which is not very reliable compared to pillow or ceramic capacitors.
You can replace the light bulbs with bright LEDs. If a LED consumes 10 mA with 2 V needed power supply the required series resistor is (Vs - Vled) / Iled = (3 V - 2 V) / 10 mA = 100 ohms. You can put additional LED in parallel and reduce the series resistor in half or you can put a few LEDs with 100 ohm resistors in parallel to power transistor.
You only needs three general purpose BJT transistors. However, you have to purchase a few in case you burn them by connecting to wrong pins. General purpose transistors are very cheap.
Rc4 only needs to be a power resistor if you are using light bulbs.
The Rb1 resistor controls to brightness of the light bulbs or bright LEDs.
Step 4: Put the Circuit in a Paper Cup or Box
You can see that the circuit fits in a paper cup.
The light bulbs are attached with sticky tape.
You can make a hole in cup with a screw driver or scissors for the potentiometer.
The lights will be seen through the cup when on.
Step 5: Secure the Wires With Tape
You can use any sticky tape.
Step 6: Attach the Arms and Legs
Use 1 mm metal wire to attach the arms and Legs to the robot.
You are now done.
Indoor Lighting Contest
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
