Introduction: Speedor Robot
I wanted to make another Instructable that was not quite so easy as my Easy Leftover Robot, but still beginner level. Also, check out this for more info.
Enclosure of choice
2 9-12 volt fans
9 volt motor
Marker
3 9 volt batteries
3 9 volt battery clips
Wheel
2 ground level springs
3 33,000 pf capacitors
Tools
Measuring tape
Hot glue and gun
Wire cutters
Drill
Hacksaw
Utility knife
Soldering iron and gear
Heat shrink tubing
Heat gun or hair dryer
Step 1: Fan Wiring
First, wire and solder your 33 k pf caps, battery clips, and fans together. Then, put your heat shrink tubing on and shrink it. You could also put it on beforehand, but I did it after.
Step 2: Motor Wiring
Do the same thing you did with the fans, but with a motor.
Step 3: Wheel
Hot glue the wheel to the motor shaft and let it dry (for a whole 30 seconds. Whew!) Also, if your wheel does not have treads, pipe some hot glue on the wheel for treads.
Step 4: Holes
Cut a wheel-sized hole into the middle of your enclosure bottom and 2 small holes in the sides.
Step 5: Assembly
Hot glue the motor and wheel to the side of the hole in the bottom. Hot glue the fans side by side on the lid. Thread the wires through the holes in the side.
Step 6: Test Drive and End
Connect all 9 volt batteries, name it, and let er' rip! I named mine Speedor. If it doesn't work, troubleshoot until it's done. Have fun!
g3holliday
