Introduction: Sponge Sensor for Scratch
(I am re-editing this Instructable to use the Micro:Bit! as Scratch 3.0 does not support it and it does support the Micro:Bit)
The sponge sensor works like a variable resister- electricity passes through a wet sponge.
As the sponge is squished more or less water lets more or less electricity pass through.
I made this to play with resistance and sound with Scratch and a sensor board...
You need to download the Scratch 2.0 program and either make your own project or use this one (this will be soon be updated to work with the Micro:Bit extension) that makes musical notes based on how much resistance there is in the sponge.
To combine Scratch and the sensor you'll also need to get a PICOboard (these are still produced - you can find them here) along with the Scratch program.
You can use the Arduino with Scratch as well - look on the Scratch forums for great programs that connect Scratch and Arduinos
Lastly the sponge sensor might be great for circuit bending as well - then all your music making materials can be free and/or recycled
Step 1: Materials
Plastic cardboard - 1 sheet ( or scrap piece at least 5x10 inches) We need plastic because this is going to get wet. Save and recycle those political yard signs!
Telephone wire - 2 pieces about 10 inches each. This is also recycled: old computer cables. It has nice colors as well.
Sponges - 1 ( you'll cut it in half to conserve) I recycle or purchase the synthentic traditional kitchen - sized sponges ( run them through a dishwasher if you want to clean old sponges.
Brass fasteners - 4 of these.
Washers - 4 small washers that just the legs of Brass fasteners can fit through.
Aluminum (metal) flashing tape - about 10 inches. I bought a roll because I use this in all sorts of projects - its great. Find it at big box and small hardware stores.
Tools:
You need:
Scissors
Utility knife
Hole punch ( with long neck if you can find one)
Wire stripper
If available:
Awl ( for punching starter holes )
metal ruler or yardstick (for guiding straigh cuts in plastic)
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Start the other piece in the center leaving a gap. 1/4 - 1/2 inch seems to work well.
Step 7:
Step 8:
Step 9:
Step 10:
Try not to bend your hole punch handles. (like I did)
Step 11:
Then get the hole punch as near to the other end of the tape - try to get it near the center. This will depend on the length of the neck of your hole punch.
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Bend the legs so it stays.
Step 17:
Put the other brass fastener through.
Step 18:
Step 19:
Step 20:
Step 21:
Step 22:
Wrap one ( circle the brass fastener a couple times) end of each around each of the brass fasteners.
Push the brass fasteners down again to keep the wire held tightly and bend the legs to hold them.
Step 23:
and you're ready to hook it up to the PICO board.
Go here to look at the Scratch project that shows how to make sponge music.
