Introduction: Step by Step Guide on How to Capture Water Droplets With a Dslr Camera
I've always wanted to capture water droplets as I find the uniqueness of the shapes fascinating.
I recently tried capturing several shots of water droplets and had great fun experimenting - my set up was on a budget and apart from the camera equipment, I used d.i.y material sourced from around the house and the local stationary store.
This guide will show you 'step by step' what I used to take the water droplet photos I have posted.
Thank you for visiting my Instructable and please check out my website featuring my latest photography work HERE
Step 1: Camera Settings
You will also need at least 1, off camera flash unit, this can be a TTL compatible flash or any 3rd party flash used on manual mode, with a wireless remote trigger and shutter release cable (i use a £20 2nd hand flash - set to 'manual' mode )
Camera settings
My Equipment:
Nikon D5000
Tamron 90mm Macro lens
Off camera Flash x 1
3 x Wireless remote trigger (you could use the camera timer or ttl of this option is not for you)
1 x mini tripod (mine is like a gorillapod but doesnt have a name and was alot cheaper £8.99)
1 x 5in1 reflector (mine is 22" £4.99 )
Step 2: Equipment for Diy Studio Set Up
1x step ladders (anywhere/anything else a bag of water can be suspended from - possibly a door frame)
1 x glass pyrex kitchen cooking bowl (£2.99)
1 x black clipboard (£0.69)
1 x pack of neon paper (£0.50)
1 x pack of holographic paper (£0.50)
you will also need a container or bag for the water to drop out of and something to seal the bag with
What I am using:
1 x fold over sandwich bag (pack of 50 £0.50)
2 x stationary clips (pack of 12 (£0.69)
1 x Badge or safety pin (£0.10)
Step 3: Setting Up the Equipment
The black clipboard can hold any background paper or card you wish to use and will change the colours of your water droplet pictures - try different designs and textures for some amazing images through the water.
You can also try using a reflector as a background and bouncing the flash off the reflector for more colour ranges in your droplets. Or try placing different coloured card underneath the glass dish - (for my droplet images I used black card under the glass bowl.
Once you have set up your equipment, its now time to be a big kid again and play & experiment with water Yeay :)
Just make sure you have a towel or cloth ready to wipe up any splashes – remember camera’s and water –do NOT mix !!!!
Step 4: Preparing the Water for the Droplets
Fill the glass bowl with water - I fill mine halfway (1") - I have been told the shallower the water, the more crown type water shots - the deeper the water the more chance of water orbs and columns - choose whichever style suits you best :)
Then with the remaining water from the jug, fill the plastic bag 1/3 with water
seal the bag - or fold over like the bag i used for my photos
Clip the two stationary clips to the top of the bag so it is secure (or use sticky tape or masking tape)
Attach the bag to the underneath of the ladder using the clips to secure, if your ladder doesnt have anywhere for the clips to attach you could also try using some garden wire to attach the clips to the ladder.
Step 5: Releasing the Droplet
Make a small hole in the bag of water with a safety pin from the badge, this allows droplets to fall into the glass bowl at a slow steady rate. - You can also experiment with different sizes of holes to reduce or increase the flow rate of the water.
Step 6: Focus Where the Droplet Will Be Landing
Another handy tip is to point a torch at the spot when you are focusing on the knife/pen as this helps your eyes get a sharp focus
Step 7: Start Clicking and Capture Your Perfect Water Droplet
The rest is down to timing and personal preference - count how long your droplets take to hit the water, press your remote trigger or set the timer for the moments after the droplet hits the surface of the water - remember a droplet performs a crown a stalk and then an orb if the water is deep enough.
- Take lots of shots, dslr cameras can cope with this - have fun learning what the droplets do with the rate of flow
- The water in the bag lasts for about half and hour before the droplets slow down
- Remember to use a shutter release cable a wireless remote trigger or the timer on your camera to take the shots, this avoids camera shake and gives you a clearer shot
- Also experiment with different backgrounds and droplet heights for more effects
- Try changing the power and the angle of the flash and also try the flash hand held – for different lighting effects –
Step 8: Last Words
The possibilities are endless – just let your imagination run away with you and enjoy capturing the uniqueness of water drops
that is about all I can think of to set up a basic water droplet studio in your living room on a budget - I hope this blog has helped :)
Update:
I have now upgraded to an automated setup and use the cognisys stopshot to take my images, which has allowed me to incorporate droplet on droplet images into my portfolio as shown above.
Thanks so much for visiting my Instructable and if you would like connect and see my photography website please check it out here
