Introduction: Streaming USB Webcam With the Intel Galileo Gen 2
Welcome!
Today we will learn how to stream a USB webcam with the Intel Galileo Gen 2.
We will need the use of "apt-get" so a Debian Linux Build is needed on your Galileo.
Follow my Instructable for Building a Debian Linux Distribution for the Intel Galileo
Compatible Devices Check
The Drivers we will be using are the UVC video drivers.
The USB video device class (also USB video class or UVC) is a USB device class that describes devices capable of streaming video like webcams, digital camcorders, analog video converters, and still-image cameras.
This link here holds a List of Compatible UVC Devices
Once you have your Debian Build SD Card and you've checked that your webcam is compatible then we are ready to move forward!
Step 1: Prerequisites
Install libjpeg-dev and libv4l-dev
Run the following commands:
# apt-get install libjpeg-dev
# apt-get install libv4l-dev
Create a soft link to /usr/include/linux/videodev2.h
# ln -s /usr/include/libv4l1-videodev.h /usr/include/linux/videodev.h
Setup Directories
# cd /home
# mkdir Downloads
# cd Downloads
Setting up a local server
# apt-get install apache2 php5 libapache2-mod-php5
Step 2: Installing Mjpg_streamer and Fswebcam
Enter the following Commands to download and install mjpg_streamer:
# wget http://terzo.acmesystems.it/download/webcam/mjpg-streamer.tar.gz
# tar -zxvf mjpg-streamer.tar.gz
# cd mjpg-streamer
Comment the following line in the Makefile:
PLUGINS += input_gspcav1.so
Make
# make
Copying Files
# sudo cp mjpg_streamer /usr/local/bin
# sudo cp output_http.so input_uvc.so /usr/local/lib/
# cp -R www /usr/local/www
Installing fswebcam
# apt-get install fswebcam
Step 3: Testing the Webcam
Plug in your webcam and type:
# dmesg
Depending on your Webcam, you'll see an input device of some sort. Mine reads:
[ 12.721488] input: UVC Camera (046d:0825) as /devices/pci0000:00/0000:00:14.3/usb2/2-1/2-1:1.0/input/input2
Change Directory to our public server:
# cd /var/www
Test your server by typing <IP-Address>/index.html in your browser
For Example: 192.168.1.2/index.html
And you should see a page with a header "It Works!
Now we will test the webcam by capturing a jpeg image and sharing it on our server so we can see it from the browser.
# fswebcam -r 640x480 test.jpeg -S 20
// The -S 20 Parameter Skips 20 Frames. Useful because some cameras will capture a black image. Downsides is it delays in seconds. Feel free to play around with the parameter.
Once the picture is taken successfully, navigate to <IP-Address>/test.jpeg
And you should see a picture of whatever was in front of your camera!
Step 4: Streaming Your Webcam
We are now ready to stream the webcam!
# cd /
# export LD_LIBRARY_PATH=/usr/local/lib
# mjpg_streamer -i "input_uvc.so -f 25 -r 640x480" -o "output_http.so -w /usr/local/www"
In your browser type in <IP-Address>:8080/stream_simple.html
Congratulations you have are successfully streaming your webcam!
Step 5: Wrapping Up
I would recommend creating a script that sets up and starts the camera instead of typing many commands each time you want to start streaming.
# cd /home
# nano runWebcam.sh
Edit the file with the following contents:
#!/bin/bash
usr/local/bin/mjpg_streamer -i "input_uvc.so -f 25 -r 640x480" -o "output_http.so -w /usr/local/www"
This script will capture a test image, remove it, set path environment for mjpg_streamer and run it
If you would like to run it in the background, add a '&' after the last command
(mjpg_streamer -i "input_uvc.so -f 25 -r 640x480" -o "output_http.so -w /usr/local/www" & )
Exit and Save.
# chmod a+x runWebcam.sh
Test it.
# ./runWebcam.sh
Check out this video of a project I came up with myself that uses this tutorial:
Joystick Controlled Surveillance Camera
Goodluck! and Thank you for reading my instructable.
