Super Low Cost Source
3,909
28
Introduction: Super Low Cost Source
About: Do you like technology? Follow my channel on Youtube and my Blog. In them I put videos every week of microcontrollers, arduinos, networks, among other subjects.
Did you realize that it’s possible to make your own source and actually spend a third of the amount you would need to buy a ready-made one? This source is with an output of four current and voltage regulators, two of them digital and two analog, which operate from 0 to 24 volts with a maximum load of 5 amps. I'm going to show you this today, which is an assembly that carries the DPS3005 module. This subject is a source of current and digital voltage, and it is a monstrous utility.
In this video today, we are going to talk about two source models. One can provide four different voltages. We also use a connector that is made for a speaker, which I think is simply great.
Step 1: Resources Used
• PB-220/140 Patola Box
• 2x 24v 10a Switching Power Supply
• 2x Digital current and voltage regulators
• 2x Analog voltage and current regulators
• 4x 10k pots + knob
• 8x female banana plug connectors
• 2 x 4-way pressure connectors
• Illuminated button
• Hi-link 5v source
• 5v 10a relay
• 1n4148 diode
• IEC connector C14 (power supply)
• 10a fuse
• Fuse holder
Step 2:
DXF and STL file, and support in DXF
Click here and download the files
Step 3: Taking Advantage of a Burnt Out Equipment Cabinet
Here, I want to show you an example of a burned out piece of equipment that I have. This is a symmetrical simple source that measures up to 30 amps.
Step 4: Schematic: General Circuit
Here, we have the general scheme of the fourfold source. But you can adapt it to make it a double source, if you prefer.
Step 5: Optional: Capacitor Filter
Here are three categories of capacitors you can add to your project and filter the output of your source.
Step 6: Drive Circuit
In this image, we have a simple schematic of how to make the switch turn on the relay. And the relay then turns on the 127V to the sources.
Step 7: Relay Connection
Step 8: Power Supply Connection
Here, I have the source scheme I used, with Phase, Neutral, and Earth.
Step 9: DPS3005 Digital Programmable Controller Connection
Step 10: DPS3005 Digital Programmable Controller
Step 11: Analog Regulator Connection (chip: XL4005)
Step 12: Hardware Mounting: Connection of the Drive Circuit
Step 13: Mounting Switching Power Supplies
Step 14: Rear Panel
Step 15: Front Panel
Step 16: Plastic Protection Against Short
Step 17: Front Panel Installation
Step 18: Assembling the Fairing and Running Test
Step 19: Source Without Analogue Regulators
Step 20: Files
Download the files:
PDF
STL and DXF
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Metalworking Contest
    Erivelton
    Erivelton
    1 year ago
    Belo projeto! Poderia colocar ele em versão pt/en aqui, normalmente faço isso em meus projetos pessoais .
