Introduction: SuperHero LightSlinger
About: LA Makerspace is a Maker education nonprofit turning LA Public Library branches (city and county) into places where kids can learn science and technology skills! If you are a librarian, or any other non-STEAM…
SuperHero LightSlinger is a fun hand band that can color mix using a Bi-LED light !
-Supplies-
Foam Pad: 1
Bi-LED Light: 1
Coin Cell Battery: 1
Paper Clips: 3
Foil Squares: 5
Twist Tie: 2
Duct Tape
Step 1: Prep Your Foam
Holding the Foam Pad long ways:
Cut off a 1 inch strip and set aside. Next, cut off an additional 1 inch strip, then cut in half.
Step 2: Insert Bi-LED
Insert the Bi-LED into the center of the Long 1 inch foam strip.
Step 3: Split LED Legs & Mark
Split the 3 LED legs into a T shape. Keeping the Negative (-) leg in the center.
Then mark each leg of LED for reference.
*Center Leg is Negative (-)
*Left Leg is Positive (+) : Color 1
*Right Leg is Positive (+) : Color 2
Step 4: Strip Ends of Twist Tie
Strip the ends of each Twist Tie down to metal. Then coil for better connections.
*Make sure to strip 1 inch of each side*
Step 5: Prep the LED Legs
Coil all LED legs. Cut 1 piece of foil in half and wrap around each POS (+) LED Leg.
Step 6: Connect Twist Tie to Foam Part 1
*Coil one end of twist tie for maximum connectivity.
Then place coil side of the twist tie over the LED POS (+) leg w/ foil and wrap tight.
Once connected, tape down. (Make sure to cover ALL FOIL & LED LEG)
Step 7: Connect Twist Tie to Foam Part 2
Then place coil side of the twist tie over the LED POS (+) leg w/ foil and wrap tight. Once connected, tape down. (Make sure to cover ALL FOIL & LED LEG w tape)
Step 8: Connect the POS (+) Side of Battery
Coil one side of Twist Tie and place on sticky side of duct tape. Then place POSITIVE (+) side of Coin Cell over the coiled Twist Tie.
Step 9: Connect NEGATIVE (-) Side of Coin Cell Battery
Coil NEG (-) leg of LED then place NEG (-) side of Coin Cell over the coiled NEG (-) LED leg.
*Tape Down & make sure to cover ALL LED LEG.
Step 10: Connect the Hand Band
Coil end of POS (+) Twist Tie and connect to Paper Clip. Then attach the ends of the Hand Band with the Paper Clip. * Make sure that the Coiled side of POS (+) Twist Tie is on the OUTSIDE of HandBand*
Step 11: Complete the Hand Band
Place Foil over Paperclip and coiled POS (+) side of Twist tie and Tape down.
Step 12: Prep the Finger Slingers
Using the 1 inch cut foams, size them for the Middle & Ring Fingers. Then use a paperclip to connect finger slingers.
