Introduction: TBAP V3. Concept Pistol (Thunder Bolt Assault Pistol)
Hey guys and girls,
I know I just posted version two of this gun, but I had some new concepts for an Oodammo pistol and I wanted to try them out. I wanted to try to make a no-friction ram lock. If successful, this would put no friction on the ram when it is being shot, but still successfully keep the pin in the gun when being pulled back. This was achieved by using mini knex. Yes, mini knex. They finally have played a good role in knex guns! The small red piece that connects regular knex to micro knex is used. The small end rides in the grove on the ram and catches the ridge on the ram. It is placed in a way so the lock adds no pressure.
The other new thing on this gun is the mag. I'm not sure if anyone will like it because we tend to be set in our ways. But the mag slides down, giving you room to fill the mag. It also uses a rod as a mag pusher and typical bullet lock to hold the mag pusher. Now you can modify it to use removable mags, but they really aren't that practical in war. One of the advantages of this mag is that it wont fire two bullets at once. The reason this typically happens is that the rod the bullets ride on is too short. That's a hard problem to fix seeing that knex only have so many connection points. But if the mag slides up and down, you can make the gap between the rod and the barrel smaller.
These are the two new concepts. I want to know what everybody thinks. It only takes a few seconds to comment.
Thanks,
Killer~SafeCracker.
Thanks,
Killer~SafeCracker.
Step 1: Step 1
Picture 1: Build these panels
Picture 2: Make these guys
Picture 3: Add them on. (image note)
Picture 4: Build these panels (image note)
Picture 5: Add panel
Picture 6: Make this
Picture 7: Slide over the rods
Step 2: Step 2
Handle Time!
Picture 1: Make all these parts.
Picture 2: add
Picture 3: add
Picture 4: add
Picture 5: add
Picture 6&7: add to the rest or the gun
Picture 8: slide the gray connector over the rod.
Picture 2: add
Picture 3: add
Picture 4: add
Picture 5: add
Step 3: Step 3
Picture 1: build these
Picture 2: Add
Picture 3: Add
Picture 4: Make this
Picture 5&6: add to the body
Picture 7&8: add to the body
Picture 2: Add
Picture 3: Add
Step 4: Step 4
Picture 1: Add this panel.
Picture 2: Add the two blue spacers.
Picture 3&4: Remember this guy? Add him on.
Step 5: Step 5
Picture 1: Build these two panels
Picture 2: Build this
Picture 3&4: Put the two together.
Picture 5: Make this
Picture 7&8&9: this is the mag. I didn't want to take it apart. You can figure it out.
Picture 10: slide it onto the rods
Picture 11: get the spacers
Picture 12: add them to the rods
Picture 13: connect it to the rest of the mag.
Picture 14: add the mag to the rest of the gun.
Step 6: Bands and Loading
Picture 1: Make the ram and get these.
Picture 2: add wheels
Picture 3: insert ram
Picture 4&5: add bands
To load pull the mag pusher down until it locks. Slide the mag down and load it with oodammo. Push it back up and release the mag pusher.
To fire pull the ram back until the trigger blocks it and pull the trigger.
I hope you like it. Don't forget to subscribe!
Killer~SafeCracker
