Introduction: How to Use IR Remotes With Arduino
I'm tired of these complicated tutorials on how to use certain things. I like simple, easy to understand, step by step instructions. My biggest problem was with IR and POV*. I've finally mastered how to control my project with any TV remote in a few minutes. In this i'ble I'm going to show you simple, step by step instructions on how to control just about anything with your IR remote.
By the way this tutorial is new and updated and works! Last update [ 10/12/2015 ]
IMPORTANT NOTICE:
With the latest release of the Arduino IDE there is a conflicting library that renders this tutorial void. If you'd still like to use this tutorial delete the library called "RobotIRemote". This file will be in the Arduino program. Instructions for deleting this file is in step 3.
This library is for a specific robot that Arduino/venders sell. Unless you intend on buying that shield you can delete that folder and continue with this set of instructions. You can always download it again later!
Step 1: Ingredients:
Electronics:
- Arduino
- Any IR remote
- IR receiver
- Breadboard
- Jumper Cables
- LED
Step 2: Downloads
Here is the link to all the downloads in this instructable.
(Sorry for some odd reason the link won't work so just copy and paste it in your browser)
http://www.mediafire.com/download/cv0r5191fvtq0y2/IR_I'ble_Package.zip
Step 3: Conflicting RobotIRremote Library
Arduino has been making some changes to the IDE, and now there is a conflicting IR library. I won't be using this library, because I still want to use the IRremote by Ken Sheriff. I've had great success with it in the past, and so have many others. So let's get this file deleted.
Mac: Applications/Arduino (right mouse click -->show package contents) /Contents/Java/libraries/RobotIRremote
Windows: C:\Program Files (x86)\Arduino\libraries\RobotIRremote
Once you have located the folder RobotIRremote, delete it. Restart the Arduino IDE and your RobotIRremote library should be gone.
Step 4: All Those Remotes!
TV Remotes, CD player remotes, heater remotes, DVD player remotes, all those remotes! Many people just have old remotes laying around because the item that they went to broke. I have collected quite a few remotes over the past week. I just asked all my friends if they had any old remotes laying around and sure enough I collected about 7 of them, so finding a remote isn't very hard. A good option if you want a professional looking one is to buy the specialty MP3 player remote. I have one because it came with my Arduino kit.
Here are a few good cheap remotes that you can get.
Step 5: Installing the IR Library
The very first thing that we need to do associating with Arduino is to download the IR library. To make things simpler, I have included a .zip of the IR library. Download it to your computer, unzip it, then place it in your Arduino libraries folder. Don't know where it is?
Open up the Arduino IDE and on the menu select Sketch>IncludeLibrary>Add Library and select the 'IRremote' folder. If you are on a PC you need to delete the mac content within the IRremote folder.
For manual placement go to
For resources here is the Github
https://github.com/shirriff/Arduino-IRremote
Here is the IR remote folder
http://www.mediafire.com/download/jd5j7911amju36g/IRremote.zip
Step 6: Recognizing IR Signals
You now need to download the IR decoder sketch.
http://www.mediafire.com/view/6qnsndqp9a838xe/Decode_IR.ino
I totally re-edited the github sketch to make it work. I put all the credits in the sketch. The sketch is attached to this step or you can get if from step 2. Upload this sketch to your Arduino. Now hook up the IR sensor.
The IR sensor's pins are attached to Arduino as so: (from left to right with the sensor's head facing you)
(Vout) Pin 1 to pin 11(Arduino)
(GND) Pin 2 to GND(Arduino)
(Vcc) Pin 3 to 5v(Arduino)
Now open up granola cereal, wait no, I meant serial monitor. Aim your remote at the sensor and press the POWER button. You should see a list of numbers show. Now you can see we got the numbers:
16753245
4294967295
4294967295
4294967295
Notice you if hold down whatever button you were pressing that the second number just repeats itself.
16753245
4294967295
4294967295
4294967295
4294967295
4294967295
4294967295
4294967295
Note what happens if you press another button
16736925
4294967295
4294967295
4294967295
4294967295
You get a different first number, and the same second number!
Obviously, we just need to use the first number. Try hitting different buttons on the remote. You will notice that each different button has a different first number.
So what you need to do is to open up serial monitor press each button, carefully recording the first number. For example: I press the power button and the mode button, so in my text editor program, I'll type,
Power button = 16753245
Mode button = 16736925
And you do this for every button you need!
With this knowledge we can construct some code!
Step 7: Arduino Test Code
http://www.mediafire.com/view/hmv13ynbihed0eg/Test_LED.ino
Some Sample code of how to use your IR remote
* Lets get started:
Pin 1 to Vout (pin 11 on Arduino)
Pin 2 to GND
Pin 3 to Vcc (+5v from Arduino)
#include <IRremote.h>
int IRpin = 11; // pin for the IR sensor
int LED = 13; // LED pin
IRrecv irrecv(IRpin);
decode_results results;
boolean LEDon = true; // initializing LEDon as true
void setup()
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
pinMode(LED, OUTPUT);
void loop()
if (irrecv.decode(&results))
irrecv.resume(); // Receive the next value
if (results.value == 0) // change zero to your IR remote button number
if (LEDon == true) // is LEDon equal to true?
LEDon = false;
digitalWrite(LED, HIGH);
delay(100); // keeps the transistion smooth
else
LEDon = true;
digitalWrite(LED, LOW);
delay(100);
This code is to turn an LED on and off with the same button. Notice this line in the code.
You will change 0 to whatever number your IR remote button makes. For instance, my power button's number is 16753245, so I will change the code to this:
if (results.value == 16753245)
results.value is just what you see in the serial monitor. So if I say, if results.value is equal to 16753245, then do such and such. Make sense?! So the rest of the code if for making the same button turn an LED on and off. When the LED if off and you hit the button it turns on and if the LED is on and if you hit the same button again it turns off.
Step 8: More Code!
So what if we want each button on the remote to do a different function? Making a lot of 'if' statements would be way too much typing! So lets simplify this with a switch/case statement.
switch(results.value)
We are going to put this after the void loop and after the first if statement. Here's the whole thing-
void loop()
{ So now we need finish the code. If you don't know what the switch/case are see http://arduino.cc/en/Reference/SwitchCase
Here is the final code. You can keep on adding cases. Now where it says 'case 03' you change the '03' to whatever button number you wish. For instance, the first case could say:
case 16753245: // do this break;And we just keep on adding different button numbers for to do different things.
Here is the link to the code below.
* Lets get started:
Pin 2 to GND
void setup()
Serial.begin(9600);
void loop()
case 01:
// do this
break;
case 02:
// do another thing
break;
case 03:
// feed my dog for me
break;
default:
Step 9: Conclusion:
I tried to simplify this as much as I can so that you can be controlling your projects with your TV remotes tomorrow evening.
If you don't understand anything please ask me!
Don't forget to give me a vote!
Step 10: Troubleshooting
Sometimes things don't go as planned so I've added a this step to help those that can't get their project to work. I want all reader to be able to experience the awesomeness of this!!! :D
If the value you receive for results.value is letters and numbers like this 'FF01XE' then you must put a 0x in front of that code to get it work work, like this: 0xFF01XE. So you project will read:
if (results.value == 0xFF01XE)
feed the dog();
}"My project isn't working!"
- READ THE IMPORTANT NOTICE IN FIRST STEP OF THIS I'BLE
- Rewire the sensor. Make sure it is wired properly. You may need to look online for your sensor correct pinout. Every sensor will not be the same as mine. Google the datasheet for your specific sensor.
- Make sure your remote is working properly. You can test this by pointing the remote at a camera and you should be able to see a dim blue/purple light flashing. Also try a second remote.
- Make sure the code works is the way I uploaded it. If you changed it you may not have the correct code.
- Retest all connections.
Well I hope these steps help if you still have problems after going through this list PM me or comment.
