Introduction: The Simple Bar Stool
As it usually goes in life, once you move into a new kitchen a need for a bar stool arises. So wife wanted to buy one but a cheapskate that I am, I told her that I'd build one that was cheaper and more sturdy. She agreed to go along but had a condition that if needed to be easy to dismantle and put away.
Step 1: Tools and Materials
One only needs some basic carpentry tools for this:
  • saw
  • hammer
  • screwdriver
  • wood chisel
  • sanding paper
As I was a bit lazy, I used a power drill to drill a hole in the top and for screwing in some screws.
Wooden parts used used:
  • 40x30x2cm board
  • 4x 70x5x5 for legs
  • 3x 36x4.5x2
  • 2x 26x4.5x2
  • 2x 27x4.5x2
  • 2x 16x4.5x2
Screws:
  • 24 4.0x30 wood screws
  • 4 5.0x50 wood screws
Step 2:
The board was 50x30 so I had to cut it to size. Next I made a hole in it so it would be easy to carry it around.
The hole you can chisel out. What I did is drilled about 50 small holes next to each other with the power drill and finished the cutting piece out with wood chisel. Sadly didn't snap a picture of the process. Also sanded out the hole.
Step 3:
Next I attached the 4 planks to the seat, leaving 2cm from the edge and enough room to fit the legs.
Step 4:
Put the legs together. Make sure that they're lined up properly else you will have one wiggly stool. The piece of wood closer to the middle is leg rest.
Step 5:
Then did 2 cm deep cuts on the sides of the legs and chiseled out excess material. Those are to make your stool extra sturdy when you fix in the horizontal supports.
Step 6:
Now attach the "seat" part onto the legs with the 4 longer screws and add felt pads.
Step 7:
A bit of sanding and all done. Feel free to paint it in your favorite color.
May your bar stools be sturdy and your beers cold!
Hand Tools Only Contest 2016
