Three Dimensional Maze
5,164
70
Tired of solving the same boring mazes over and over again? This 3D printed maze will have you thinking in three dimensions! Based off a childhood toy, this game will (hopefully) have you stumped for hours. Not hard enough? Now you can design your own interchangeable parts for ultimate enjoyment.
The goal of the game
Each side of the multidimensional puzzle has a starting square. You must navigate a ball through a series of corridors and tunnels to get from one checkpoint to the other. Once you've completed the task, your ball is already set to make the journey back to its original square.
Make sure to check the attached images for additional notes!
All attached STL Files are formatted in millimeters
Step 1: Design
To create the layout of my maze, I plotted a rough draft of one side onto a piece of graph paper. Once I was happy with the design, I digitally recreated the sketch in Adobe Illustrator. I decided that this side would be the top of the maze.
After finishing the first side of the maze, I printed the pattern and began to plot the paths for the second side that would connect all of the separate slots that were previously planned on the first side. During this planning phase, it was important to ensure that all of the slots would be accessible by the ball bearing and that there would be no closed loops within the maze.
Once again I digitally replicated my design for the second side and marked the locations of the holes connecting each slot.
Step 2: Modeling
With the digital drawings complete, I designed a grid that I could eventually convert to a .SVG file to use in creating my 3D model. I then, using the new grid, proceeded to create three separate .SVG files: one for the top maze, one for the bottom maze, and one for the middle divider that would contain the tunnels (holes) to allow the ball to pass from one side to another.
I then separately imported each file into my CAD software of choice and extruded the main components.
Finally, I created a simple enclosure to contain the three pieces as well as the two panes of Plexiglas.
Step 3: Materials
The following Items will be needed to complete this project:
  • Access to a 3D printer
  • 3D printing filament: two colors is recommended.
  • Two 6" x 6" x 0.05" panes of Plexiglas
  • A 5mm ball bearing
  • Glue to adhere enclosure
To cut Plexiglas to size, score both sides with a blade along a designated cut line. Once there are deep groves of either side bend the material until a clean break is achieved.
Step 4: 3d Printing
For this project, I used a Creality Cr 10 3D printer.
While the parts might look simple enough, the print time for each side of the maze surpassed eight hours each due to the high number of walls.
I would suggest using skirts to lock down the more complicated parts and prevent any shifting.
Clean the prints and ensure that there is enough space for the ball bearing to pass through all gaps.
All necessary STL files are linked below.
Step 5: Assembly
The actual assembly process is super easy. First, ensure that all the pieces are properly aligned with a start and finish square on opposite corners of the maze. Each of the five panels should easily drop into the printed enclosure with the top piece of the case snugly resting between the pegs of the main body.
The diagrams provided in step two can be used to check if all the pieces are in their proper orientation. Each diagram is viewed top down.
Order of parts from top to bottom:
  • -top-
  • MazeCase2.stl
  • Plexiglass
  • MazeTop.stl
  • MazeHoles.stl
  • MazeBottom.stl
  • Plexiglass
  • MazeCase1.stl
  • -bottom-
Once all of the pieces are in place (don't forget the ball bearing), the two bodies of the case can be glued together to prevent anything from falling apart. If you are looking for a less permanent solution, a few strategically placed pieces of tape can be used as a substitute.
Step 6: Play!
The objective of the maze is to get the ball bearing from one corner to the opposite corner on the opposing side of the maze. Once you've found your way across you're all ready to puzzle your way back to the start!
Step 7: Files
All five of the attached STL files are formatted using the metric system (mm). Good luck!
7/10/2019 - MazeHoles.stl file updated to correct conversion error in object height
Colors of the Rainbow Contest
Eighth Prize in the
    • Stone Concrete and Cement Contest
    • Sensors Contest
      Sensors Contest
    • Beauty Tips Contest
      Beauty Tips Contest
    2 Discussions
    offseidjr
    2 days ago
    Cool idea! Aesthetically pleasing and simple enough to build, considering you have access to a 3-D printer.
    PriestJason
    Question 5 days ago
    Can you please post a video of this project completed and being used? I would love to see how it works. Looks fanfreakingtastic in the pictures. My late Dad bought us, as kids, that tilt labyrinth to teach us hand-eye coordination. The game has two knobs that you turn and depending on how the table is leaning the steel ball roles around the maze, The point is to avoid the holes and make it through the maze to the end. If you fall in a hole you start over. It worked magic for my coordination as I love to work with my hands to create projects, draw pictures, write calligraphy with fountain pens, use tools, build and ride motorbikes. It didn't help me with video gaming though, I am that guy that runs around in circles aiming at the sky and the ground, twisting and turning and running into walls and other players who are online haha, I know you all have at least one friend who plays like me. If you do decide to add a video please let me know so I can watch the maze in action. Skäl
